Why does my spi mp3 player not work
Stays on the Screen with the little computer icon and devise icon it says its charging but does not charge what to I do
SOURCE: dell dj mp3 player won't charge
You need to install the Playforsure firmware update. That will solve the problems.
Posted on Jan 12, 2008
SOURCE: accurian mp3 player problems
Hello Guys ... I got it solved !!! here's what I did:
1- Go to www.mymusix.com
2- clik on FAQ, then on 43-198
3- find the solution for this question :Q: When I turn on my player it says 'Error, connect to PC and use Device Manager to repair'., and click on link
4- Follow the instructions
If after following all the instructions, you still can't see the device on windows, click on downloads, then on 42-198, then download the mpt utility and run it, the do the above steps again
hpe this helps
Posted on Feb 03, 2009
SOURCE: i-scream mp3 player (AV-1)
i have no problem with the charge on my i-scream av-1 mp3 player, but when i add songs from the computer onto it from the usb cable, as soon as i disconnect, and i try and listen to the music i just put on, it wont let me play it and it has deleted all of the other songs i had on before i added more.
Posted on Oct 27, 2009
  • 608 Answers
SOURCE: MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Mar 28, 2010
  • 3 Answers
SOURCE: How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Posted on Apr 23, 2010
I plugged my mp3 player into my computer and how can I tell if it is charging and when it is done charging?
Go to "my computer" (or whatever it's called in your operating system) and right click on the MP3 icon, pick properties it will show a battery with the percent of charging.
Aug 12, 2016 | Eclipse Fit Clip 4GB* MP3 Player
How do I know the sandisk is fully charged
I just bought a Sansa 8GB Clip, when the battery is completely charged the yellow battery icon (at the top right of the screen, to the right of "Connected") stays solid and is not animated, with the center horizontal bar completely filling the inner section of the icon. While it is charging the center horizontal bar is animated and slides from right to left. At no time does my battery icon turn green.
Jan 19, 2011 | SanDisk Sansa Clip MP3 Player
Do i need a computer to charge my m.p.3. player
Hi
yes you need a computer to charge your mp3 player if you do not have a charger for your mp3 player
To charge your mp3 with a computer you should swiych it off then connect one end of a USB cord to the mp3 player and the other end to the computer (just like you want to transfer files)
The screen of your mp3 player will light up and you will see an icon or word indicating that the mp3 player is charging.
Jul 04, 2010 | Philips GoGear SA2825/37 MP3 Player
My little sister's Spi mp3 player won't turn on
If you are saying that you had it plugged into a computer, and the first time you used safely remove hardware, and the next time you did not.
Then the device was in the read state and is stuck, you can remove the battery, then put it back in, then turn off the computer, turn on the player
(if it is not working ) plug it into the computer with it turned on, and start the computer, after the computer has loaded windows, check to see if the devise is listed under my computer, if it is try the safely remove hardware and see if it works now.
Feb 13, 2010 | Audio Players & Recorders
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Feb 03, 2009 | Archos Internet Media Tablet MP3 Player
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
Sony walkman 4GB NO RESPOND/FROZE with screen saying"WALKMAN"
there is a reset button hold it down for 10-30 seconds....prolly what you are doing is not allowing the comp to disconnect thru icon 1st before you dissconnect the mp3 player.....btw if you do this to often the computer can start acting up
Dec 02, 2008 | Sony Walkman NWZ-S616F MP3 Player
Trouble charging my zune
I would say make sure you are in the right USB port. My laptop has 3 and only one of them will charge my mp3 player
Apr 12, 2008 | Microsoft Zune JS8-00001 Digital Media...
CHARGE
I had a similar issue and found that it would only charge if the mp3 player was turned on and the computer was not only on but the screen saver was turned off as well.
Dec 27, 2007 | Sears TGE MP3 Player
Mp3 not working
i can't help with ur mp3 not working but i had a similar problem with my mp3 not charging i just realized you had to turn it on it didn't say on the guide book it came with but i'm creative n then i turned it "ON" and it was charging i hope i helped someone with this simimlar problem
Nov 29, 2007 | BenQ Joybee 125 MP3 Player
13 people viewed this question
 Grubhead
Grubhead
