Question about Coffee Makers & Espresso Machines
Astoria SAE2N - tl the lights stay on for the buttons but nothing comes out. When I press the dispense buttons, water congress it off spouts behind the metal panel and goes into drane pan but nothing out if heads. The hot water spout fits nothing when I press the button either. The steamers work though, but it seems to be really hot water that instantly turns into steam. The guages go into the blue zone but nothing else. What could be the problem
EsWorld
  • 1618 Answers
SOURCE: no coffee coming out, just hot water
Two questions:
1- Is the coffee grounds wet or dry?
2- Does the spout drip water when the machine is just heating up?
If the grounds are dry then the brew chamber is not getting any water. Turn machine off, let it cool down, then remove brew unit. Behind the brew unit there is a white valve with 2 red o-rings(sometimes black), if you look closely there is a small lever between the o-rings, get a small screwdriver and gently lift lever and spring, if water came out then the problem is in the brew unit, unscrew the stainless steel screen which is under the large red O-ring on the brew unit and clean, also make sure the tube on the unit is clear.
If the hot water spout is not dripping when the machine is heating up then you're good.
Posted on May 14, 2009
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Posted on Aug 12, 2009
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
  • 92 Answers
SOURCE: Hello The lights on the front
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Posted on Jan 14, 2011
SOURCE: When machine is on, water trickles out of steamer
Konstadt's solution is brilliant. Worked for me - exactly as described.
Posted on Feb 06, 2011
Water does not dispense through the coffee spout
Did you cheak if the spots are blocked did you run some clean water ? The milk further is a different section from the coffee try and consentrat on the coffee part run some clean water is there any noise is the water going in to the trip tray because the spout are blocked ? Next go inside and cheak driver relay or seloniod stay safe if you not such don't do it
Jul 06, 2014 | DeLonghi Magnifica Coffee Makers &...
Astoria sae 2n . the lights stay on. They do not flash. Nothing comes out of the heads but water did come out of spouts that are located directly behind panels. There seems to be one for each espresso head...
Has the machine been cleaned / descaled? Coffee machines become clogged with mineral scale deposits from the water. Some folks use citric acid , about two tablespoons /qt of water, and some folks use white vinegar, 1/2 & 1/2. Place the solution in the machine as if you were making coffee. It may take a few cleanings if there is a lot of deposits. After cleaning dissolve two tbsp of baking soda in a quart of water and run through machine to neutralize the acid.
May 13, 2014 | Coffee Makers & Espresso Machines
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
flash.
it anticlockwise.
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
No water is pumping thru the water spout or the coffee spout, the machine is reading fine grounds and press okay for water. i've adjusted grinder dial and pressed water button but nothing happened
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
Sep 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Miele CVA610 error reads expel air but when we do as manual suggests (run hot water & milk frother) no water comes out.
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another
under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in
quiet, continuous streams.
- Press the hot water button again.
Turn the steam selector clockwise to o, to turn off the water.
If this doesn't do it for you, you are doing it wrong!
Oct 06, 2009 | Miele CVA610
How do I program an astoria SAE-2 espresso machine?
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
Sep 28, 2009 | Astoria Argenta SAE-2 Espresso Machine
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Aroma 3.0L electric heater/kettle stop dispensing
I waited about an hour and it the problem stopped.
Dec 13, 2008 | Aroma Kitchen Appliances - Others
Water won't dispense
check water container in fridge is not frozen up
Jun 19, 2008 | GE Refrigerators
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
