I have a 7.8 inch tv/ DVD player by audiovox, and I received it without a remote. Is there any way for me to use the tv and go into menu without the remote? Or do I need to buy one?
I need the codes to program a magnavox tv with built in dvd player with this remote
Your universal remote should have a code search feature that allows you to search through its library to find a code or codes that will work. You might need two separate codes for the TV and the DVD player.
Jun 19, 2015 | Audiovox RCR314WR Universal Remote Control...
The Audiovox Rca RCRN04GR Universal Remote Control
Try to Google the model numbers of each for "manual" to see if available.
Jun 07, 2012 | Audiovox Rca RCRN04GR Universal Remote...
How can i access the menu without the remote control?
On older Televisions such as the one you have listed, you cannot access those menus without a remote control. Just to make sure I skimmed the user manual found here. The only suggestion I have is to get a universal remote with a menu button. Dont forget to check with your other remotes to see if they have universal functionality. Most receivers (surround sound units) have multi-function remotes. Also check your satellite or cable remotes to see if they have universal functions. You can tell, because they will have multiple buttons that say things like "TV, AUX, CABLE, ETC" If so, you can program one of these remotes (or grab one at most electronics stores to program) and have your menu available to you.
Also, check the link to make sure there isnt some functionality hidden away that I didnt see.
Cheers!
Feb 23, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
Need a remote that works for TV and DVD player
Go to Remotes.com and put your model # in, they do have the original for $30.00
Feb 26, 2009 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
Dec 13, 2008 | Audiovox D1210 Portable DVD Player with...
Jensen VM 9512 DVD Player
goto the set up menu, tap the language tab, ON THE REMOTE push "stop, stop, 5,4,3,2,1" and the secret menu will pop up
Mar 19, 2008 | Audiovox VM9512 Car DVD Player
Audiovox model VOD715
Also program it as a DVD. That seems to work. I had the same issue.
Dec 13, 2007 | Audiovox VOD715 Car Video Player
Hooking up a DVD Player with NO remote
Some TV's will let you access inputs by going through the channels to the very end and see if it works.
Jul 29, 2007 | RCA F25674GY 25" TV
Televison & Video Logo
Top Televison & Video Experts
