if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
wot should it rev to at max revs ? is 4th gear top gear , if so are the sprockets original size as a smaller rear spocket will make it go faster but you can loose top revs in top gear and if carbs etc havent been adjusted to cope with this !
Before Windows boots, determine which keyboard command you need to type to enter the "setup" or BIOS. Hit that key and it should get you into the BIOS. Once in the BIOS, go to the boot priority settings and set the DVD to boot first. Normally the harddrive is first.
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
You should be able to use your recovery disk? If that's what you are using and getting that problem then I would call the factory and have them send you another recovery disk cause yours might be bad.
Try IBM Proprinter III XL, 3287, Epson FX, Any Dot Matrix Printer Driver. The 4247 drivers cannot be used for the 4230.
The 4230 is a seriously old printer. You might want to consider getting a new one.
