Question about Centric 2005 Jaguar S-Type - R - Premium Rotors
Error code 50 51 on blank screen
Blank screen after trying to loan bluetooth without manual. mechanic can not fix. could screen die????Controls not working,ac is blowing out top of dash.
Why does my 2001 cavalier die when coming to a stop?
If it dies when you are coming to a stop after being on the freeway, chances are the torque converter solenoid is sticking in the transmission.
If it is doing it around town, I would look at the throttle body and idle air control valve. The computer controls idle speed by regulating air flow into the throttle body.
Jan 10, 2013 | 2001 Chevrolet Cavalier
My nokia n73 bluetooth not work properly.
first please format the phone using this code
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try to use the blue tooth
the problem raises again ,the problem is relating to your bluetooth ic ,please check it and change with the help of a mechanic
your gallery have any problem in loading (slow) ? that is also the reason of ic compliant
thank you
please rate me if it helps
Oct 22, 2010 | Cell Phones
Goodmans TW28D11, Flashing green light, screen blank
well, if you have access to the owners manual, the flashing green light may be an error code. check the manual! if no manual, try their web-site, they may have a faq section for that model, or even an error code listing!
good luck!
Oct 08, 2009 | Televison & Video
Xbox is showing one red light in the lower right hand spot. How do I fix this
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Sep 24, 2009 | Microsoft Xbox 360 Console
The screen on my nokia 6288 went blank ,is there a way to repair it??
Were you using Bluetooth at the time?
I've had 2 Nokia 6288's. The first one died the day I got it. I'm pretty sure I was bluetoothing music from my Mac to my phone. The phone went blank, every time I turned it it would just flash, then turn off. So I returned it and got a new one. It was fine for ages, then it did the same thing when I was bluetoothing stuff to it. I got it fixed, and last week it died again-still flashing.
I think it cost about $100 to have it fixed, but I'm not fixing it again. I got a new phone, the Nokia 6300-My dad has one and has never had any problems-and it's had stuff sent to it from my Mac.
Jun 20, 2009 | Nokia 6288 Cellular Phone
Iphone won't work with bluetooth in mazda 3 2010 My iphone shuts off whenI try to use the bluetooth system in my mazda 3
iPhone has had bluetooth since the first model in 2007. With iPhone OS/firmware 3.0 (free for all iPhone users), iPhones are fully A2DP compliant and link with Mazda bluetooth.
My current experience is with a 2010 Mazda3 and iPhone 3GS, where I get phone and iPod functionality via bluetooth (yes, without jailbreaking), though the steering-wheel controls are limited to play/pause and volume only.
Jun 12, 2009 | Apple iPhone 3G
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
PHP Blank Screen
can you send me the source code of that webpage ?
Thanks.
Sep 03, 2008 | The PHP Group PHP
Bluetooth error and infa
your bluetooth inside the phone does not make proper elctrial contact on the board ta it to the service provider to re install the bluetooth device. advice by dogy.
Dec 16, 2007 | Samsung SGH-D500 Cellular Phone
Centric 2005 Jaguar S-Type - R - Premium Rotors Logo
505 people viewed this question
Top Centric Video Game Consoles & Games Experts
James Wishart
Are you a Centric Video Game Console and Game Expert? Answer questions, earn points and help others
