Question about Dell Alienware Area-51 Gaming Desktop Computer (Intel Core i7 930 640GB/12GB) (DPPCPW11)
What would cause the monitor to go black while playing various games.
Playing any particular game, the monitor loses signal from the video card. I have checked the cable on both ends. I have even swapped out the cable with my other PC. Computer is only two weeks old. Thoughts?
Add new graphics card to check
is working 100%......
Posted on May 17, 2014
    New Friend:
  • 6 Answers
Being that its so new, i would just send it back for warranty work. Sounds like a video/graphics card going bad.
Posted on May 13, 2014
  • Philobios May 16, 2014
    It does not at all sound like the card is 'going bad'. GPU's don't 'go bad'. When they burn, they stop working altogether.
  • 4 Answers
This model can be ordered with several different GPU, depending on customer preference/budget. The desktop does NOT offer integrated GPU nor does the i& 930 does NOT perform integrated GPU-functions.
All that to say that this sounds like GPU-Driver problems. Update the GPU drivers to the latest from the manufacturer directly (do NOT use any 3rd party drivers and do NOT download them from anyone but the manufacturer).
If the problem persists after this, it is likely that the CPU is a bottleneck for your GPU, and you were undersold on the model. Alienware rigs are far from the monsters they used to be before DELL bought them out and severely sucked the life from their product line. You would be further ahead to return this and build your own rig.
If the latter is the cause, you may be able to overclock the CPU, but bear in mind this will almost certainly void any warranties you have - and will likely result in failures since none of the devices in that rig are intended to be overclocked.
Posted on May 16, 2014
    ... and make sure to disable 'User Account Control' in your OS!!!
  • Brian Hayes
    Brian Hayes May 21, 2014
    I returned it. They sold me a significantly upgraded version and everything has been working great for the past two weeks.
tom19511
  • 1601 Answers
SOURCE: Computer turns on, but there is no display on monitor.
The builtin video card is probably bad. Yes, you can get a PCI video card.
Posted on Dec 28, 2007
SOURCE: WANTING TO UPGRADE RADEON ATI X300 SE VIDEO CARD
You have a PCI expressx16
Posted on Mar 29, 2008
CapitolG
  • 23 Answers
SOURCE: No video display
If the video card is built into the motherboard then try starting in safe mode and reinstalling the drivers from scratch. Download the latest drivers from the dell website. Safe mode will reduce the resolution and use a generic VGA driver. If your video card is plugged into a PCI slot try unplugging the video card and using a different slot and going through the same process. If you are still not getting any output to your monitor and you are positive the monitor is fine then you may need a new video card. To be sure, if the video card isn't embedded to the mother board, you could take it out and try it in a different computer. Hope that helps.
Posted on May 23, 2008
  • 11 Answers
SOURCE: Dell C521 Where to connect monitor?
This means that you have an external video card (which is not outside the computer). This video card will be plugged into the motherboard. That message is saying that the port on the back of the computer that your monitor is plugged into is the wrong one. You need to look for another port on the back of the computer.
Here is a picture of a VGA port that you should use if you have a VGA cable to connect the monitor (Blue Ends).
http://news.softpedia.com/images/reviews/large/VGA.jpg
Here is a picture of a DVI port that you should use if you have a DVI cable to connect the monitor (White Ends).
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
So depending on the cable and connections that are available on your computer and your monitor depends on what you have to use. I hope that wasn't too confusing. Let me know if you need more info.
Posted on Feb 12, 2009
  • 11 Answers
SOURCE: My Dell Optiplex GX1 will not boot. The Monitor shows no signal.
check whether ur ram is working or not. remove the cpu side door and remove the ram from the ram slot and clean it using a eraser gently and fix again it back and power ur pc on and check it
Posted on Feb 23, 2009
What-are-the-best-card-games?
The best card game that is liked by most of the people worldwide is Poker Online.
These online poker games includes:
a. capsa stack
b. domino qq
c. ceme online, etc.
I also love to play this poker games online. You can also play it against various players globally via registering on the link provided above.
Dec 14, 2015 | Video Game Consoles & Games
When playing games on my computer my monitor will blank out
First make sure your video card driver is up to date, and the monitor driver as well when they are available. If the computer reboots when this happens, there is a hardware conflict potentially.
If the monitor goes black like it was shut off abruptly and computer did not shut down- replace all the electrolytic capacitors in the monitor on the power supply board. This should forestall an inevitable failure of the monitor.
Feb 12, 2012 | Gateway FPD2275W LCD Monitor
My Screen goes totally black; "No signal or something) and the light goes from green to orange. Im just playing World of warcraft and suddently this happends (multiple times now) I need to...
You can check the compatibility of the game with your graphic card, or you can try changing the resoluion or the quality of the graphics while gaming.
Hope this one helps. thanx
Apr 03, 2011 | BenQ G2411HD Monitor
VGA Falcox 955, 128T DTV AGP
The game is using all the video ram which is causing the problem. You can try running the game with the bare essentials running in the background but newer games seem to want at least 1 GB of video RAM. Hope this helps.
Feb 14, 2009 | ATI RADEON X1650 Graphic Card
ATI x800xt Graphics Card freezes when playing 3D Games like flight simulator
Greetings,
Usually that happen once the resolution of your monitor cannot meet the desire need, it depends the kind of monitor that you have even if you change different kind of video card, its still happend.
Try to change the resolution to lower one.
Here's the step
1. right click on the desktop ( a place where there is not icon on your screen)
2. choose properties
3. then settings
4. adjust the screen resolution to lower settings some on the color setting
5. then ok.
Thanks.
Oct 30, 2008 | ATI RADEON 9550 Graphic Card
Problem watching movies & playing games(screen flashes black on & off
HI
This may not help, but you can try to lower the resloution to another widescreen format.
I'm thinking you may have your resolution maxed out and the video card is having problems with the movie games because of that. Possibly not enough video memory
Movies will work fine at lower resolutions, Not sure about all the games but they probably will too.
Fran
Oct 15, 2008 | Computers & Internet
Loss of DVI video/black screen
The problem is probably related to it showing the wrong video card. I would see if there is any help for everquest on changing that and if you cannot figure it out I would reinstall the game and that should fix your problem, keep in mind that you may have to uninstall in order to reinstall properly.
Mar 12, 2008 | NEC MultiSync 90GX2 (Silver, Black) 19"...
No signal
This sounds like your Video card might not be compatible with the game you are playing. You might need a better video card. Before you do anthing else, check to see if your computer is fast enough to play it.
Big games can crash slow computers, also it could just be a bad monitor.
Try checking the cord between the monitor and the computer.
Feb 23, 2008 | Acer AL1714 17" LCD Monitor
My moniters screwed
Sometimes this is due to graphics cards, but most of the time it is due to drivers. If it does not happen when you are using your PC for other things the problem probably just lies with the graphic card, driver, and this particular game or any game similar. Drivers are the most notorious! Check your requirements on the game for graphics cards recommendations! Let me know!
Oct 10, 2007 | Acer AL1916W 19" LCD Monitor
GeForce 6800 Gt, Unusable signal
Could you post your system information as well? CPU, memory and so on.
Dec 19, 2006 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Dell Alienware Area-51 Gaming Desktop Computer (Intel Core i7 930 640GB/12GB) (DPPCPW11) Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
