Code P 2310
No communication to ecm
    New Friend:
  • 6 Answers
Check PCM fuse. Check power wre to ECM and see if there is voltage going to it.
Posted on May 13, 2014
2004 infinity fx35 code c1130 and no start no blown fuses or fuse links any ideas
Possible causes Faulty Engine Control Module (ECM) Faulty ABS actuator and electric unit (control unit) Control Area Network (CAN) communication line Blown ECM fuses What does this mean? Tech notes The code means that the Anti-Lock Brake System (ABS) control unit has detected that there is a problem with the Engine Control Module (ECM). What does this mean? When is the code detected? Based on the signal from Engine Control Module (ECM), the Control Area Network (CAN)-Local Area Network (LAN) converter (CLC) judges that the engine control system is malfunctioning. Possible symptoms ABS Warning Light ON Scanner cannot access Engine Control Module (ECM) C1130 Infiniti Description ABS actuator and electric unit (control unit) and ECM exchange the engine signal with CAN communication line. Major engine components are malfunctioning.
Read more: https://www.engine-codes.com/c1130_infiniti.html
Dec 07, 2017 | 2004 Infiniti FX35
What are the probable causes of DTCs P1603, P1604, and P1605?
OBD-II code P1603 indicates an issue with TCU communication.
There are communications that exist between the engine control module, or ECM, and the transaxle control module, or TCM. This communication is done through a control area network, or CAN. With the communication of the CAN, an independent pin and wiring is needed to receive a signal that includes sensor information from the ECM. The more information there is to communicate, the more wiring that is needed. When it comes to CAN communication, all of the information communicated is done alone control modules like the ECM and TCM using CAN lines. When there is a problem with these lines, the ECM will detect the problem and store a P1603 trouble code; the storing of the trouble code is what causes the SES or check engine light to illuminate on the dash.
Possible causes of trouble code P1603 include:
  • Faulty transaxle control module (TCM)
  • Faulty engine control module (ECM)
  • Harness running from the TCM to the ECM has a short
  • There is a poor electrical connection between the TCM and ECM
Diagnosing the exact cause of the problem should always begin with a visual inspection that could reveal bad wiring, loose connections, or damaged parts. From there, it is a matter of running down the list to determine what needs to be replaced. In general, a bad ECM will cause a loss of power, poor fuel economy, and stalling engine. While a bad TCM will have more prevalent transaxle issues like erratic shifting
P1605 and P1605
These codes are indicating a starting problem and rough idling. Code p1604 is a very vague code and diagnosing it without having a symptom is very complicated. And code p1605 is rough idling which means that the computer have noticed a rough idle situation usually this code is accompanied by other codes or if it's alone then I would suspect a fuel pressure issue. These two codes involve diagnosis and we'll need to dig into this problem deeper to find out what's causing them, Unless you are an experienced technician who need assistance then I will suggest that you take your vehicle to your local toyota dealership and they should be able to find the problem.
P1P
Feb 12, 2016 | 2011 Toyota Sienna
Communication link
code readers need the correct pins to communicate to the ECM . You will have to say what the car is and what engine as there are a number of cables that can be connected .
Jan 04, 2014 | 2007 Hyundai Sonata Limited Sedan
U2105 lost communication with ecm car wont start. could there be anything causing this other than ecm
If you are getting the fault code saying that it lost communication with the ECM there could be something faulty going on with your ECU. This usually will not cause the car to not start, and will make your engine run strange or cut off while running. There can most definitely be something wrong with another component in the vehicle that would cause it to not start properly.
Oct 17, 2013 | Roadi Rdt61 OBD2 Diagnostic Trouble Code...
What is code B2799
This Diagnostic Trouble Code (DTC) is output when the Engine Control Module (ECM) detects errors in communication between the Transponder Key Electronic Control Unit (ECU) assembly and the ECM, or in the communication lines. This DTC is also output when an engine start is attempted while the ECU communication ID between the transponder key ECU assembly and the ECM is different.
Possible causes Faulty Key Faulty transponder key amplifier Faulty Transponder Key Electronic Control Unit (ECU) Transponder key amplifier wire harness Faulty Engine Control Module (ECM)
Mar 02, 2013 | 2007 Lexus ES 350
I got a code from auto zone that is i believe UO 101 AND UO105 OR UA101 AND UA105 WHAT do these codes stand for
These codes are communications code errors:
The UO101 is a transmission communication error: poor communication to your transmission ECM / computer
The UO105 is a fuel injection communication error: Poor communication to your fuel injector ECM/ computer.
Jun 15, 2011 | 2006 Dodge Stratus
Obd code U1041
Codes U1XXX (where XXX stands for several possible numerical digits, 001 - 254) are communications fault codes. The first part (U1) tells you that there is a communication problem with one of your many onboard control modules. The second part (XXX) or in your case, (041) tells you which module is not communicating. It can vary from year to year, model to model. so without knowing the year and model of the vehicle we are talking about, I cannot tell you which one.
In any case, there is a module that is not communicating with the other modules that are sharing information through the Class 2 serial data circuit. One module uses U-codes to tell on the other modules. For instance, If you got the U1041 code out of scanning the Engine Control Module, you can bet that the Engine Control Module is not having a problem communicating. If it was, you would get a non-communication fault from your scan equipment and the ECM would not tell you anything. Instead, the ECM is telling on the module that is not communicating properly .
I like to call these codes the 1-800 codes...THE PHONE LINE IS DOWN... lol ;)
Nov 24, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Code b2799
Hello I happened to me a problem in my car check in the computer system and Dahr me On B2799 So how fittest Alco possible Chrahola Hza case and thank
Apr 28, 2010 | 2006 Toyota Camry
Security code for nokia
I have forget security code nokia 2310 my imei 355532011097717
Aug 23, 2008 | Nokia 2310 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
