Question about ASUS P5RD1-VM Motherboard
I can't use any sata hardwewr on my motherboard
I have the same problem. my Motherboard does not know of any SATA Hard Ware . i have asata dvd writer but ican't boot using it .my mother board type is asus - psrd1-vm
please tell me what can i do ?
Create a sata diskett[floppy] using your motherboard cd and press F6 when booting from xp cd this will install sata raid drivers for your motherboard
Posted on Jul 10, 2009
    Sergeant:
  • 220 Answers
Try changhing the boot sequence, if you've done that, try making sure the SATA raid option in you bios is Set as IDE
Good luck
Posted on Jun 23, 2009
    President:
  • 1,383 Answers
When you power up computer press F2 or "del" ketyto enter in bios then go to advanced and enabled SATA option.
Then save settings.
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
How do i setup sata dvd writer on asus motherboard p5s800. It does not see the writer
Hi dtoitj4, You have to find where the settings are for SATA mode in the bios.
Check the jumper settings on the back of the DVD burner you just installed, make sure that it's set for slave.
Let me know for any clarifications.
micro-
Dec 12, 2009 | ASUS P5S800-VM Motherboard
Hi my ASUS K8S-MX motherboard is not detecting SATA hard drive and Sata DVD Writer. Though my IDE hard drive and DVD Writer is working fine. Please help me with this .
Two thing here that can be the issue.
1. Bad Sata controller onboard
2. Sata controller is disabled in the bios.
The Fix
1. Purchase a independent sata controller there like $25 bucks.
2. Try going into the bios under advanced and make sure its not disabled.
I sure hope this finds your Very Helpful vote! Have a Merry Christmas and a wonderul New Year!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 07, 2009 | ASUS K8S-MX Motherboard
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
PC Does not boot up with LG SATA DVD Writer
Did you try to move the small jumper next to the connector on the back of the DVD writer.
Then try to choose different places to connect your DVD on the motherboard.
Check if you have the right driver or reinstall it.
Hope its help, don't forget to rate.
Cheers
Aug 19, 2009 | ASUS K8V-MX Motherboard
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Samsung SH-s203 dvd writer is compatable with this motherboard
put the sata cable to sata terminal and also connet the sata power cable to drive.
Oct 28, 2008 | Intel D845GVSR Motherboard
ASUS P5RD1-VM Motherboard Logo
443 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
