Question about Handi Quilter HQ Pro-Stitcher Computerized Quilting System for HQ Sixteen
My electronic displays on the Sweet 16 freezes after about 15 minutes of use. I have the stitch regulator attached. What might cause the screen to freeze?
When using my Sweet 16 sit down, my electronic display freezes. The machine continues to work fine, but unable to access anything on display. When the machine is turned off and then back on, the display temporarily unfreezes. I am also using the stitch regulator with the machine. I've already replaced the display and new display continues to freeze up. Any ideas?
Can A stitch regulator be fitted to a Janome Memory Craft 8900 QCP PLEASE ??? Thank you
If your machine had a stitch regulator option, then you would have to purchase the specific accessory for your machine and you may need to have a technician set it up for you. Otherwise, you are probably out of luck. A stitch regulator is a complicated accessory that needs to be calibrated to work with your machine, meaning it also has to be electronically connected to the machine.
Nov 16, 2017 | Janome Sewing Machines
Activa 220. freezes up
Sounds like a computer board is failing.
Sep 03, 2017 | Sewing Machines
Can I add a BSR to a Bernina 1260?
Not really. The Bernina BSR units need to be attached electronically to the machine to activate the "electronic eye." Your 1260 is an earlier mechanical-electronic machine that does not have that electronic-attachment capability, ie there is no where to plug a BSR unit into your machine. However, with practice (both with pencil on paper and then transferring that muscle memory to the machine), you should be able to learn to free motion quilt on your 1260. It just takes practice and patience.
BERNINA Stitch Regulator BSR
https://www.qnntv.com/courses/improve-freehand-quilting-designs-using-muscle-memory
Apr 01, 2017 | Bernina Sewing Machines
Can I buy a stitch regulator for my janome memory craft 4800?
If the machine has the capability for a stitch regulator, then it is most likely possible. However, stitch regulators need to be attached (electronically plugged in) to the machine. If your machine does not have that, then you are limited to manual stitch regulation. (However, that may not be a bad thing. There are still a lot of professional sewists who continue to perform manual stitch regulation (such as free motion quilting) on mechanical machines. Their work is beautiful, but they have had a lot of practice. Even if they were offered a stitch regulator, most probably wouldn't want it anyway. Harriet Hargrave is probably one of them.
Harriet Hargrave Professional advice and the highest quality supplies for... The last time I saw her working on a quilt, it was a whole cloth silk quilt that she was quilting using a mechanical Bernina.)
You can contact a Janome dealer or search online. It should also be listed as an optional accessory in your paperwork.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj-lejWiKbQAhUH6WMKHYLXBPcQFggjMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fretired%2Fcomputer%2Finst-book-mc4800.pdf&usg=AFQjCNGCPQc_wJyl_Ts_4bFZ-7M3hX1ZnA&cad=rja
Nov 13, 2016 | Janome Sewing Machines
Which is the stretch stitch on my elna club 500
Here's a copy of your owner's manual:
ELNA 500 ELECTRONIC Manual Page 16
Although it does not show a "stretch" stitch per se, there are several that can work. Machines without any stretch stitch can simply use a zig-zag.
Jun 10, 2016 | Elna Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
Needle not picking up stitches
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? o
May 16, 2015 | Janome Sewist 525S Mechanical Sewing...
My DDL555 the stitch regulator is not working, getting long stitches only
hello Osvaldo
regarding your problem please check attached two photo, hope it's helpful for you to resolve the problem.
best regards
ASHRAF ABOZID
CAIRO-EGYPT
Feb 16, 2015 | Juki Sewing Machines
Handi Quilter HQ Pro-Stitcher Computerized Quilting System for HQ Sixteen Logo
32 people viewed this question
Top Handi Quilter Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Handi Quilter Sewing Machine Expert? Answer questions, earn points and help others
