Question about Pioneer DVD-V555 DVD Player
Pioneer DVD-V555 dvd tray will not open
How do I open the disk tray on a Pioneer DVD-V555 system. Tray door appears to be stuck. It says open and then stop but the tray does not open.
  • 883 Answers
SOURCE: Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Posted on Jun 04, 2007
  • 7 Answers
SOURCE: dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Posted on Dec 31, 2007
SOURCE: pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Posted on Mar 08, 2008
SOURCE: DVD stuck/jammed in tray
unplug unit, then plug in, let unit boot up, then with the remote open tray. works every time
Posted on Apr 26, 2008
SOURCE: Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Posted on Jan 29, 2009
Sony cfd 646 - cannot open disk tray
Some have a tiny hole in the tray front to manually release it/push the tray open.
Dec 20, 2016 | Sony Televison & Video
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
The disk tray won't open. There is a dvd in the tray and I played it back but, when I tried to eject it, the tray door would not open.
check if something is blocking the door to open.if no then the gears in the internal area are either worn out.apply the oily substance in the sides of the dvd gears to make it move frequently.
thanks.
Oct 29, 2008 | Lite On Televison & Video
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Dvd tray won't open
Don't take the cover off. Open the door and use a small flat instrument to depress the tray release buttom (it is indented on the lower right hand side of the tray. If there is a disk remove it. Turn off your system and the tray will close. Restart you system and see will the trat open.
Jul 15, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Dv-c503 pioneer dvd player
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
DVL-V888 disk tray
you will have to take apart and see if you can push the disk into position other wise have to take apart tray system and remove disk.
Dec 03, 2007 | Pioneer DVL-V888 DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Pioneer DVD-V555 DVD Player Logo
19 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
