Question about Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
The other motor which rotates the fan, is working. The shaft moves freely, not clogged, when rotated using hand.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
Posted on May 13, 2014
4 Suggested Answers
  • 497 Answers
SOURCE: fan vibrates
Vibrations are a cause of friction. I can only assume that the motor or the fan veins are being interferred with. If you feel comfortable you can take the case off and look or take it to a repairshop and have them look it over.
Posted on Aug 20, 2009
  • 13 Answers
SOURCE: the fan has stopped blowing it rotates and the
Try reversing the fan by using the switch or another chain in the cub. You might have accidentally reverse the fan
Posted on Oct 03, 2009
SOURCE: the fan has power and will rotate, but no air is
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Posted on Dec 30, 2010
Soleus Air FSH-40G fan would not start. The bad seems harder to rotate. what could have gone wrong? How to fix?
First unplug the fan for safety. Next add a couple drops of motor oil on the shaft that turns with the fan blade. Tip the fan blade at about a 45 degree angle when adding the motor oil. Spin the blade by hand at that same angle to allow the motor oil to flow down the shaft, inside where you cannot see the shaft. It should start turning by hand a lot easier now.
Sep 06, 2015 | Soleus Dryers
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
Ok my ace 2000 disposal hums. blades move freely when i put my hand inside. the 1/4" allen wrench doesn't fit in the opening at the bottom. my sink fills with water but eventually drains, so I...
Sounds like the starter winding is bad.
The cutter disc is welded directly to motor shaft. So is the allen wrench fitting.
So if disc rotates freely, then you should be able to feel the allan wrench fitting rotate too.
Use broomstick instead of hand down disposal.
If motor hums and cutter disc does not spin, but cutter disc can be moved freely, then disposal needs to be replaced.
I wish they made repairable motors so that metal and copper doesn't get thrown into the scrap recycle metal bin.
I wrote ez disposal replacement tips:
http://beta.fixya.com/support/r7929008-replace_garbage_disposal
Oct 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
WHEN PRESSING START UNIT JUST HUMS
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Nov 26, 2010 | Amana Dryers
Inside fan not turning on, outside unit is turning on
First turn the power off and see if the fan is rotates freely. Turn it by the shaft and not the fan blades. Its easier to feel the resistance. Next check you capacitor. If that's good then check the fan windings for continuity.
May 29, 2010 | Goodman CKL42AR42 Air Conditioner
Fan blade won't turn, but will slowly turn if given a push. What is the problem? How do I fix it?
Replace the fan motor capacitor. If that does not correct the problem you will have to replace the fan motor.
May 12, 2009 | Goodman CLQ36AR49 Air Conditioner
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Seville Classics MSC10166 Tower Fan Logo
536 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
