Question about Amana Microwave Ovens
Fan wont shut off
I have a model mvh140w over the stove microwave, was cooking in it,microwave shut off then few minutes later the fan kicked on and wont shut off, even after unplugging.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
SOURCE: Microwave Fan won't shut off, no display
Depending on which brand you have I would think that the Thermal switch on top of the magnetron or one of the door switches has probably given up the ghost. However, if the display does not come on you probably have a micro or Psu fault on the display panel. Not to be attempted if you are not familiar with microwaves or electronics. Please unplug before opening. Good Luck, JUS004
Posted on Jan 05, 2008
  • 9 Answers
SOURCE: Kenmore 665 68610891- built-in 1998 model
Fan relay on circuit board stuck. Give it a tap (the relay), to free it up. Otherwise get the relay or driver transistor replaced. Easy fix. Take it to an electronic repair place, not the brand agent.(They,ll just replace the whole board).If this Item is under warranty you should not be wasting my time.:::Spiceweasel.au
Posted on Apr 04, 2008
EwingElect
  • 276 Answers
SOURCE: GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Posted on Mar 25, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 23, 2009
Why can i not cook for 20 minutes with oyster microwave it cooks about 7 minutes an shuts off then about 5 minutes later it starts up again.
The unit could be overheating and shutting down, cooling off, and restarting. Check ventilation holes on back for dust accumulation and blockage. Check that cooling fan is turning properly.
Nov 26, 2017 | Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 27, 2014 | Kenmore Microwave Ovens
When door is shut some type of internal fan kicks on...
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Mar 09, 2013 | Frigidaire FMV157GM Microwave Oven
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
prototech@usa.net
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
