Question about Minolta bizhub 200 All-In-One Printer
Minolta bizhub 164 code m2 - Minolta bizhub 200 All-In-One Printer
    President:
  • Minolta Master
  • 1,447 Answers
Press the Utility button,
then Stop 0 0 Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Which are very important for copy quality, and not replacing them may cause more harm than good.
Posted on Jul 17, 2014
3 Suggested Answers
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
Konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
Dec 21, 2014 | Konica Minolta Office Equipment & Supplies
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
replace the drum and developer and then reset the counter
Konica mintola bizhub 164 maintainace call (M2)
replace the drum and developer and clear the counter also ensure you run the F8 after developer been replaced and new drum are installed
Mar 25, 2014 | Konica Minolta Office Equipment & Supplies
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
then Stop 0 0
then press again Stop 0 1
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
Konica minolta bizhub 164 reset code m2
Utility button then stop 00 stop 01. use arrows to get to clear data. then to maintenance counter clear/yes
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
CARA RESET M2 BIZHUB 164
bagaimana cara reset bizhub 164 error c2558 mohon penjelasannya
Jun 28, 2012 | Office Equipment & Supplies
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
Minolta bizhub 200 All-In-One Printer Logo
77 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
