My Simpson Encore 756 flashes HC. What does that mean
Simpson Encore 756 flashes HC error. What does that mean?
4 Suggested Answers
SOURCE: simpson washing machine encore 756
our simpson encore 756 flashes SP can anyone tell us what it means and how do we fix it thanks mark
Posted on Jun 18, 2010
SOURCE: simpson encore 756 flashes sf
Motor overloaded wait 15 minutes, press start stop.
Posted on Nov 13, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Posted on Apr 01, 2011
Hw do i reset machine settings on a simpson encore 816
Don;t understand what you mean. A bit more info on what the problem is and why you think there is a way to reset it would help.
Jul 31, 2016 | Simpson Washing Machines
Why does my Simpson encore 556 display SF on the Display panel. What's it mean?
If the control panel detects that the motor is not rotating then it will beep & show that fault.
Feb 26, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Hello
Apr 01, 2011 | Electrolux Washing Machines
Simpson encore 756 flashes sf
Oct 04, 2010 | Washing Machines
Says sf on screen Simpson encore 807
i have a Simpson encore 807 & its displays DF what does that mean... as it keeps beeping...
Jun 30, 2009 | Washing Machines
Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Jan 11, 2009 | Washing Machines
Simpson washing machine encore 756 displays error df and will not complete cycle
Aug 03, 2008 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
