Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
At first we noticed that the ice cream was not freezing completely. Then we noticed that the items in the door of the freezer were not frozen. Finally we noticed that the suction sound that we would hear when we closed the door originally was now gone. We have checked to make sure that nothing is effecting how the door closes and that there is nothing between the door gasket and the freezer body.
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
Posted on May 15, 2014
2 Suggested Answers
SOURCE: Freezer is running but the items are thawing and not freezing
it could possible be the defroster unit going out on the thermostat theres a hole on the bottom where you can access a screw that will allow you to check and see if the defroster is working put a srew driver in the hole and turn it clock wise till you here it click and then listen for the unit to start defrosting cycle you'll hear a hissing like sound if its working if not you'll need a new defrosting unit
Posted on Jul 24, 2009
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
Frigidaire freezer has ice accumulating and not freezing properly. Ice cream will not freeze.
Try turning the temperature control to off, unplug the electrical power cord from the power outlet, defrost the appliance, clean the condenser, plug the power cord into an electrical outlet, set the temperature control to a low setting, lay a thermometer in the freezer for a few hours and see what happens to the temperature in the machine.
Check the integrity of the seal of the door gasket by seeing how the door seal will hold a slip of paper in various locations along the freezer door gasket. A loose hold on the slip of paper shows an area where hot moist air can get into the freezer and cause ice build up.
Aug 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My hotpoint under counter freezer isn't freezing properly
A freezer has a very simple operating design and there are only 2 customer serviceable components.
1. Make sure the cold control is set at the proper level.
2. Make sure that the door seal is making good contact with the cabinet. You can apply a thin coat of Vaseline to the door seal to help tight closure of the door.
Keep the door opening to a minimum during extreme heat conditions. Any small air leak can drastically reduce the operating norms during extreme heat conditions.
That's about all that you can do to regain control, the rest will have to be performed by a refrigeration tech. if you are still dissatisfied.
Jul 05, 2009 | Amana Freezers
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
178 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
