Question about Frigidaire FWS445RF
How do you check control switch frigidare washer model number fex831cs it does not drain water
  • Frigidaire Master
  • 5,323 Answers
WHY ARE U SO SURE ITS THE CONTROL SWITCH?
Posted on Mar 31, 2015
jumptrout51
  • 3361 Answers
SOURCE: I have a frigidare frontload washer that won't
Check your drain pump for obstructions.
Check the drain pump motor if nothing is found in the pump.
Posted on Mar 15, 2009
marka19
  • 1430 Answers
SOURCE: Frigidaire FEX831CS Top Load Stacked Washer won't
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 03, 2010
  • 144 Answers
SOURCE: My frigidare front loading washer
Sounds like a programmer fault , is it stuck , is it a geared one , ie can you turn it by hand to select next cycle. if so give it a gentle turn .. could be the pump clogged .
pete
Posted on Nov 17, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidare washer, model LST6000ESO will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Jun 26, 2011
langman_kevi
  • 3 Answers
SOURCE: My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Posted on Feb 29, 2012
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
Washer won't fill with water
Hi Allen, this is JK. I see that you are having trouble with your washer (FEX831CS) not spinning or filling with water. For the washer not spinning, check the drain hose length and make sure there are no restrictions. The concern could be with the timer or the drain pump. For the washer not filling, I would check the water pressure, pressure switch and the water inlet valve. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off an on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
Water drains out the washer the same time it is trying to fill
Hi- First thing to do is check the drain hose into the wall and make sure there is a bend, 180 degree, loop that is higher than the highest water level in the washer. It is possible that the water is siphoning out. If the drain hose is set-up ok then it sounds like the drain pump is being activated on the fill. Hard to say exactly what is causing this it is most likely either a switch in the timer or the pressure switch are activating the pump at the wrong point in the cycle. You should have a Tech out to look at it.
Sep 24, 2010 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Water leaking from bottom of frigidare washer
You really don't have to take a panel off, depending on your washer model. All you would have to do, is flip the washer over on its side and check underneath.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer not draining water
If the machine does not drain start checking the drain hose.
Ifthe drain lines are not clogged, then you will need to access to thedrain pump, and clean it , or replace it if it is not working.
Machine not draining can also be caused by a defective timer control, but this is rather unfrequent.
See also : It won't drain
This seller also have replacements and delivers worldwide.
Dec 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
