Question about TitanNet PowerStar Replacement battery for City Bug e2 Electric Scooter
My city bug scooter just beeps when I turn it on. I just put in a new battery. It worked for a bit. Now it just beeps. I do not have a button on the bottom to push. Help....
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Scooter from the front and it should be on the underside of the scooter , or the main fuse might be blown....
http://www.kymco.com/upload/CTContent/6/644A6FCF-D327-4F9A-8A2D-67168B67ECE6/AGILITY_CITY%2050%20125.pdf
Posted on May 13, 2014
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Constant beeping but scooter will move
okay there sounds like there either water somewhere or condensation ?
place the whole scooter in a warm room next to a radiator, not too close but close enough so it gets the warmth leave it like this to dry out, this has worked for me, water causing a short either under the tiller panel or where the controller is situated.
regards
Dec 15, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
How do i reset the service spanner symbol on my aprilia 125 leonardo sport city scooter
Ok, disconnecting the battery does NOT reset the service light. To reset the service light (spanner symbol) on dashboard you must hold the mode button for about 5 seconds with ignition OFF then while still holding the mode button turn ignition on, continue holding the mode button for a futher 10 - 12 secs and then it should just disapear. This solution was brought to by RPMs. Mobile motorcycle service.
Oct 30, 2010 | 2007 Aprilia Sportcity 250
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
TitanNet PowerStar Replacement battery for City Bug e2 Electric Scooter Logo
168 people viewed this question
Top TitanNet Toys Experts
ray gallant
Are you a TitanNet Toy Expert? Answer questions, earn points and help others
