Question about Lands Phones
Norstar M7208 - How to change pulse to dial?
Hi everyone. Could you please help me out with step-by-step guide how to change dial mode pulse to tone for Norstar M7208? I found how to change standard, automatic and pre-dial mode, but it's not what i need. thank you.
  • Didi
    Didi May 14, 2014
    Fafa, i don't have PROGRAM button. Only Feature. It that the same I guess?
  • 92 Answers
  • Didi
    Didi May 14, 2014
    Thank you, but it gives me only temporary solution. I need to make tone mode permanently.
  • 5 Answers
SOURCE: Lucent Technologies 925 Phone
If memory serves, to program the touch tone, lift the handset, press [PROGRAM] # # # 3 then hang up.
Posted on May 26, 2007
SOURCE: Tone Pulse
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
Posted on Aug 17, 2007
SOURCE: Hoe to make a Three way call
Make your first call, press hold. Make your second call (internal or external). Press the conference button, then the display will tell you to press the other line (the first one you put on hold).
Posted on Dec 30, 2007
SOURCE: changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Posted on Jan 06, 2009
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
Want to change dial pulse out dialling to DTMF tone dialing
unless your phone supports that (and has a little switch somewhere), you just can't. Get another phone, sorry !
Jan 22, 2014 | Nortel Meridian Norstar M7208 Mics Cics...
Cannot get the pulse tone off the line and that prevents from voicemail access and call forwarding HELP!
In guessing that since your lines have defaulted to pulse dialing that you have an older Nortel system such as an 8x24 or a 6x16 system. That being said you'll need to program touch tone dialing on each line.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
4 top line/feature keys are now used for programming
Press the show key (top right arrow)
the display will say1. trunk/line data
Press the show key (top right arrow) .
the display will say line 001.
the display trunk data
press the show key (top right arrow) Press the next key 7 times(bottom right arrow) .
The display should say Dial mode: pulse.
Press the Change soft key (below the display).
the display should now say tone. press the heading key (top left arrow) to get back to "trunk/line data" repeat the steps for the remainder of your active lines
press Rls when finished
Nov 04, 2010 | NorStar M7208 Corded Phone
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
Norstar m7310 phone
Rushy: I assume you have a KSU which controls the entire system. The KSU is cabled to each line number provided by your local phone company. Once you have this line established it now makes contact with your phone set via dedicated cabling to each telephone set.. With all this hardware in place you can now program the line keys on each set for either one touch dialing or line access for your dial tone. Program guides can be aquired through GOOGLE by entering " Norstar m7310 program guide".Thank You. Jerry
Feb 08, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
97 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
