Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
How do you check control switch for frigidare washing machine washer does not drain
SOURCE:
catriver
  • 878 Answers
SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
Posted on Jun 11, 2006
  • 50 Answers
SOURCE: how do you change the control motor board on a
Access is from the back of the machine. Motor control is on the left side tucked in beside the motor.
Posted on Feb 26, 2009
ssebata paul
  • 159 Answers
SOURCE: WONT DRAIN
clean the pump and also make sure that the pump motor is powered during draining
Posted on May 30, 2009
  • 56 Answers
SOURCE: WASHER WONT DRAIN
Take off the lower panel ( 2 screws on bottom) pullout and down to remove. Make sure unit is unplugged pump is on the right hand side one hose coming from bottom of tub and the other goes out the back to the drain. Take off the hose from the bottom of the tub and be ready to catch alll the water in the tub suggest you use shop vac and remove all water first. look in the impellar in pump should be a clog right there then put everything back the way you toook it off and be careful to get the hose back on the way you took it off there is a slot in the hose and a tab on the pump for alignment.
heatman101
  • 43501 Answers
SOURCE: daughter washed a feather pillow which fell apart
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 30, 2010
My frigidare (ATF6700FS1) reads error 23 it will not spin
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
MY FRIGIDARE INFINITY WASHER STOPPED SPINNING AT ANY CYCLE...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2011 | Whirlpool GHW9200L Front Load Washer
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
WONT DRAIN
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidare Front Loading Washer model# FWT645RHSO
check out the drain pump if drain pump is blocked up water will not get away quick enough and stop machine from spinning
if that is clear
turn bowl by hand and if you get a runble noise then the main bearings are gone
that will need dismantle and replacement or new machine
Mar 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
