Question about Hunter 27185 Remote Control
THE FAN IS NOT WORKING ,WHATS SEEMS TO BE THE PROBLEM
    Top Expert:
  • Hunter Master
  • 43,979 Answers
Assuming it is a ceiling fan, there may have been a power interruption making it necessary to "reset" communication between the remote and the receiver inside the fan housing. Disconnect power at the source, not at the fan, pause briefly then turn on power and check operation.
Posted on May 13, 2014
ATTEMPTING TO INSTALL A RECEIVE MODEL SR 400 TO FAN MODEL CF 2454 BS 01 NOT ALL FUNCTIONS ARE FUNCTIONING...WHAT IS WRONG?
Mixing wall switch control with pull chain (?) operation seems to confuse the receiver. Best to choose one or the other and stick with it.
Feb 23, 2018 | Emerson CF2454 Ceiling Fan
I have a 1998 Ford Escort Wagon and my AC/HEAT works but it doesn't blow out. IT trickles out faster the faster I drive, but it seems the fan is not working. Also, I thought I had a radiator leak but it...
Your friend is right. To answer your other question these are two totally seperate fans but that does not mean that one fans fuse or relay did not affect the other. You should check your fuses and which ones, if any, are blown. It is likely that during your radio installation a bare contact touched something and blew the fuse(s). If the fuse is blown and, when you replace it and work your heater fan, it blows again then chances are your radio may have cut a wire upon sliding it in. Reply back to this post and let me know.
Nov 30, 2010 | 1998 Ford Escort
Freezer doesn't seem cold enough, took over 24 hours to make ice cubes!!! Small fan at the back of the freezer doesn't seem to work regularly, fridge seems ok
If the fan in the refrigerator (evaporator fan) isn't working properly your machine isn't going to be as cold as it should be and your ice maker won't work properly as well. This is due to the fact that the ice maker has a sensor in it and it won't produce ice unless the sensor tells it is lower than 10 degrees F. A rule of thumb is if the condensor fan motor is running, which is the fan located by the compressor, than the evaporator fan should be running as well. Now, with that said, there evap fan is tied into what they call a bi-metal thermostat. Depending on the brand these sometimes go bad causing the fan not to run, but that wil cause it not to work at all. If its working intermitantly, than chances are the fan motor is bad.
Nov 08, 2010 | Refrigerators
I have a 2005 Jetta 2.5 and it seems like one fan runs to fast
One fan should run when engine is running. Other fan should run when AC is on.
Jun 28, 2009 | 2005 Volkswagen Jetta
My fan stays on
More than likely, the remote is bad. The part that is behind the cover over the ceiling box is often failing before the 1st year is out. You can relpace what you have with another, or there are after market remotes that seem to be better.
Nov 28, 2008 | Hunter 52" Ceiling Fan With Light And...
I have model # RS2630WW Samsung regrigerator making a lot of noise that seems to be coming from the back panel area. When I remove the 8 screws, it's seems to be coming from the fan. (I disconnected the...
fan can not be lubricated and they can get noisy.
however, a common reason is the fan blades hitting ice that has built up. check for this
Sep 06, 2008 | Refrigerators
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Televison & Video Logo
280 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
