Question about Dryers
FAN DONT WORK NO MORE.IT GOT POWER,LIGHT WORKS
    Genius:
  • 1,617 Answers
Need more info! Make/model of fan, how were you operating fan when it worked ( remote,pull chain,wall control)
Posted on May 14, 2014
Hello .Head lights dont work. low speed fan for AIR conditioner dont work.EPS Light come on from time to time.
Need more info than lights don't work and fan doesn't work. Can you provide the model number of the unit and a walkthrough of what it is doing?
Jan 14, 2018 | Heating & Cooling
Cookerhood
  • are you saying your lights and fan does work or they dont? but just in general check and make sure your power source is functioning properly.,next check any and all fuses then ( note) A professional should be doing this because there is a real electrical hazard here!!!!. that being said.after you do the aboved mentioned. also checking all connections check your transformer,relays and motor .,,,but with none of it working definitely check your power source fuses connections and transformer first
May 27, 2013 | Heating & Cooling
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
Motherboard
Does the power supply fan spin up? does the cpu fan spin up? do any of the lights work? does the machine make a beeping noise? Is it plugged into the mains and switched on? is the monitor plugged in and switched on?
Jun 24, 2012 | Matsonic MS9367E Motherboard
My 1991 isuzu trooper heater blower fan is not working, nor when i turn it to the airconditioner the compressor does not engage. i checked all the fuses except the ac relay fuse block, what could the...
if the lower fan speeds dont work but the fastest speed does the heater fan resistor block needs replacing. If the highest fan speed doesnt work leave it on there and check for power at heater blower fan, if power is on one wire and the other is an earth the blower motor fan needs replacing. Use a normal globe test light to check this. If no power on any wires to fan go back and check all fuses in car and under bonnet with same test light. If fuses are ok possible open circuit wire to fan.
Jan 13, 2011 | 2004 Isuzu Rodeo
The heating fan won't turn on, no power to fan. intermittent problems with the selector buttons not lighting up and working to select mode. all fuses and relays check out fine. do i need to replace the...
no, you may have two problems, the fan il bet is a blower motor resistor,replace that and fan will work again, the selector problem may just be bulbs not lighting, if you can can air to blow in areas you select then dont worry about the light not lighting, if it dosent select then replace the head, hope this is helpful.
Dec 07, 2009 | 1994 Buick LeSabre
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Computer will not swtch on.light just flashes.fan works etc.
First check the power supply cable to the motherboard remove it and then open the cpu unit remove the 20 or 24 pin power cable wait for 30 seconds and replace it after that try to start the pc
if it will not work the try to replace the powersupply unit wth a new one and see its switching on most of the time when peoples see those light and fan working they dont look back to the power supply.
Actually the power supply will switch through the motherboard if there is no proper voltage the motherboard will not function but you will see flashing lights and working fans.
After that you check with your VGA card and check for any cables are disconnected or not
If still it not working you need a techinican help.
Jul 18, 2008 | Computers & Internet
79757 lights
It might not be the bulb but the socket (If you have incandescent sockets). Inside each socket there is a piece of metal that the bulb connects with. Check to see if it is flattened out. Turn the power off then get a flat head screwdriver and pry that piece of metal back outward. Turn the power back on and screw the bulb in slowly till the bulb lights.
Mar 04, 2008 | Aloha Housewares (93645) Ceiling Fan
Dryers Logo
21 people viewed this question
Top Dryers Experts
