Question about Canon CanoScan LiDE 80 Film Flatbed Scanner
Scanning arm stuck on flatbed scanner & makes a grinding noise.
Canon CanoScan Lide 80 flatbed scanner.
When trying to scan the scanner makes a grinding noise and the scanning arm won't move. An error message appears (code:201) saying to consult the manual which i've checked and can't find any reference to the error code. I've checked the scanners lock on the back of the machine and that appears to be broken as it is stuck in the unlocked position and can't be moved. As far as I can tell the problem appears to be mechanical, can any one help?.
SOURCE: CanoScan LiDE 20/LiDE 30 Mac 10.4.9
This seems to work with fink/xsane or the canoscan drivers from their site, but neither as well as you might like.
Posted on Dec 11, 2007
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
I had the same problem more than 1 year ago and then found the solution (at least in my case that is) somewhere on the internet. Since I have the same problem with a new computer I searched the internet once more, but did not find the solution. However, last time I was so clever to write down the solution on the disk of my old laptop. The laptop is gone, but not the disk, so I could access it by putting it in an USB enclosure and was able to find the solution once again. Here it is:
c:WINDOWS wain_32CNQLxx (xx is the number of your scanner) should be included in the PATH environmental variable.
Now I know where to look for I found the link where I found it first:
http://www.everythingusb.com/forums/showthread.php?threadid=7337
The entry was by pallosp.
Posted on Nov 04, 2008
SOURCE: canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
Posted on Apr 11, 2009
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
Driver for mac 10.5.8 required
Canon CanoScan LiDE 80 Drivers
Please visit the above link from Canon Official. Select the Operating System (OS) you have on your PC and download the required drivers & software.
Hope it helps! Good Luck!
CreativeTECH
Mar 01, 2011 | Canon CanoScan LiDE 80 Film Flatbed...
When I try to scan with my canonscan lide 70 I get a message "specify the program where the scanned image is transferred"
You just need to point the program to where the scanning program was installed. If you just let it auto-load it should be here: (assuming you loaded the free toolbox software)
C:\Program Files\Canon\CanoScan Toolbox Ver5.0\CSTBox.exe
or just look at where the toolbox is installed by searching for the CSTBox.exe file.
Mar 06, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Is canonscan LiDE20/30 compatible with wndows 7
Here is the link for downloading the drivers for canoscan lide 20 for windows 7 (compatible with XP, Vista e.t.c).
Canoscan lide 30 does not support windows 7, here are the drivers for Vista.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 25, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Have no installation disk for canon lide 80 scanner . OS X 10.6 (Snow Leopard)
An error message popping out saying:
release the lock switch, deatach the I/F cable and receoonect.
scanner driver will be closed.
Code: 2,179,0
I have unlocked it and recoonect the cable. but my scanner cant seem to scan through it.
Oct 30, 2009 | Canon CanoScan LiDE 80 Film Flatbed...
Clicking noise scanner stuck
have you checked the scanner lock ? it should be off.
May 13, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Drivers for Canon Lide 25 not working
Where are you scanning from? What application? Did you download and install Toolbox as well as the driver?
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=11463
Jul 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Help
You'll have to do that in the software that handles the image after scanning. Do you start scanning from your computer, or direcly on the scanner? While executing the scan from the computer, you can select the save-path there. While executing directly on the scanner you need to to go to the settings of your scanner, i think.
Mar 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
Jan 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan LiDE 80 Film Flatbed Scanner Logo
325 people viewed this question
old marine
old marine
