Question about Intertherm P3RA-030K Air Conditioner
S3RA-036K capacitor size and part number
    Sergeant:
    Champion:
  • 234 Answers
Any capacitor of the same rating as old one will work, it doesn't have to be a Intertherm part. I would say its 25-35 ufd 370v.
Posted on Nov 26, 2014
2 Suggested Answers
  • 230 Answers
SOURCE: s3ra-036k Compressor will not come on
Too many options. But anyway I would first look at the power supply. If there is power I would look at the contractor, is it pulling in, and is it calling for cooling. If the contractor is not pulled ini would check the 24v supply to the contractor and make sure iris there and the t-stat is calling for cooling. If it is then we move to the coil on the contractor and make sure it is not open. If there is no 24v to the contractor the you need to check the safety's on the discharge and suction lines going to the compresser and the t-stat. If there is power there and the contractor is pulled in then I would put my hand on the compresser, if it is very hot, then she is pooched. If it is cold the. You need to check the windings for an open winding which means she is pooched. I hope that helps a bit.
Posted on Sep 08, 2012
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
Coleman mach part number 8530B735. tell me what size capacitors I need?
size of capacitors will read like 30/5 mfd-you should be able to read this on the capacitor. otherwise call a supply house (wholesaler) and they will look up the number. or call coleman.
Oct 26, 2016 | Coleman Heating & Cooling
The size of the capacitor
The size of the capacitor is stamped on the side of the old capacitor. it's the number just in front of the letters uf. Example 100 uf, 40 uf etc.
Nov 23, 2015 | Heating & Cooling
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
What size capacitor do i need for a 2.5 ton compressor
Each brand of unit uses different sized capacitors I need a model and serial number of your unit to actually cross reference that part. You could also call the manufacturer of you unit and find out.
Aug 26, 2014 | Heating & Cooling
What size run capacitor do i have to get for a mitsubishi muh12tn
Best thing to do would, is look at the one that is currently inside of it, and just find a local Ac supply house, and take the capasitor with you and purchase a new one, Normaly if you look at the numbers on your current capasitor it will have the number with a UF just to the right of the number.
Nov 05, 2013 | Mitsubishi MSH12TN Air Conditioner
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
Pool pump sp2607x10 hayward capacitor????
They can vary from year to year.
There is a model number and a code number on the motors label.
Jul 21, 2012 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
What type of capacitor comes with a 5 ton Goodman Air conditioning unit model number CK60-1C
The best way to know what size capacitor it needs is to look on the label of the fan motor itself. It will tell you the size it needs. Condenser fan motors get replaced all the time with different capacitors needed. If you cant find a label or its too weathered, try to find a model number on the fan motor and any local A/C supply store will be able to look it up. Hope this helps.
Jun 21, 2010 | Goodman CKL60AR60 Air Conditioner
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
Intertherm P3RA-030K Air Conditioner Logo
310 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
