Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere 14sb
Is the opening at the back of the deck to put a hose to clean under the deck? It looks like a hose fitting. There was a lot of built up old grass under there. Thanks
  • John Deere Master
  • 2,478 Answers
That it.
Posted on May 13, 2014
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Posted on Nov 16, 2009
huffman49
  • 235 Answers
SOURCE: John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Posted on Apr 11, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
  • 640 Answers
SOURCE: My John deere LT 160
Check the blades, I expect that you will find that they are wearing out.
Posted on Aug 30, 2011
Will a john deere snowblowerfrom a 445 fit on a 485 john deere?
You will need longer hydraulic hoses because the ports are on the opposite side of the 485 but will work. If the 485 has mower deck it will have to be removed or buy a quick hitch to set the blower back a little further. Go for it....
May 29, 2017 | John Deere Garden
How to change a pulley on a John Deere 48 c mower deck
You must remove the deck from under the mower by removing all clips and connectors to the main mower under body. There are 3 small bolts attaching each pully wheel to the deck body. If you are lucky the bolts will remove correctly. I recommend that you use a liquid wrench product on the bolts. The new pully should have grease fittings which the factory units do not. Also the bolts cut in to the metal holes if removed bolts came out cleanly. You may have to drill out the broken bolts then screw in the new ones. Make sure you grease the new pulleys. I replaced all three rather than wait. The original ones did not have grease fittings and they will wear in two..
Oct 12, 2014 | John Deere Garden
How to fit a 48 inch deck to john deere x110
Who told you that would fit? Take it back and get your money back.
Dec 13, 2013 | John Deere 22HP VTwin 48" Riding Mower
Drive does not work on a john deere 14sb
Wow a 14 sb, The best mower John Deere ever built. Hopefully its just the belt. If it is the transmission cable, they dont make it anymore.. You get a longer one. Before you buy anything, make sure the cable is routed correctly. Sometimes when you fold the handles the cable gets to the outside of the handles, it needs to stay on the inside and not bent ovet the take down knobs. If they are all routed good and it does need to be replaced you will need to order a new lever GX2206 and a new Push
nut GX10434, they are needed for the new cable to work. Hope this helps.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 09, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I am working on a john deere 14sb and can't get a spark from the plug. Is there a part that can go bad that causes this? Thanks.
Yes, the ignition module. It is located under the top shroud beside the flywheel. Replace it and set the gap between it and the flywheel magnets to 8 thou with a feeler gauge. Hope this helps, regards Phil.
Jul 02, 2011 | John Deere Garden
I need a diagram of the belt on a black deck John Deere STX38 can you assist Thanks Deb
Follow this link: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt then do a "model search"
click on which model (either yellow deck or black deck) alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or this website:
OutdoorPowerInfo.com © 2011
Or just 'google':
Installation of John Deere STX38 and STX46 Hydro Drive Belt (Black Deck)
Good luck.
Mar 05, 2011 | John Deere Garden
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do we service the blade / brake clutch assembly on John Deere 14SB lawn mower .
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Nov 14, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
77 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
