Question about Acer Computers & Internet
What brand and model does this computer have
Can I add more USB connectors?
  • Acer Master
  • 3,320 Answers
It would be better to add an external powered USB hub.
Posted on May 12, 2014
Headphones usb not working
try uninstalling and then re-installing it.
Plug the USB connector into an available external
USB port on your computer or laptop. On most
computers, drivers install automatically and your
headset will be ready to use.
Note: On windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
If you can not hear audio on your headset, adjust some or all of the following settings:
• Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
Jan 22, 2012 | Dynex Mono USB Headset with...
I am looking for a firewire cable from my usb port to my video cam (firewire..canon brand but i forgot the model
Firewire is the IEEE1394 standard and is completely different from USB. If you want firewire, get an interface card to add the port to your computer.
Oct 03, 2011 | JVC GR-D270US Mini DV Digital Camcorder
Has a USB connector that when I connect I can not use my Google Talk - what am I doing incorrectly? Best, Yvonne
try uninstalling and re-installing the headset. Plug the USB connector into an available external
For any audio issues:
• Restart computer.
Sep 24, 2011 | Dynex DX-840 Headset
I can't find where my microphone goes
Is your computer a laptop or a desktop? How old is it? Which make/model of computer do you have?
For an older desktop, the microphone input will be on the back of the computer. There are usually three 3.5 mm jacks for audio connections. The pink connector is for the microphone. The black connector is for Line In and the green is line out (speakers). Often they are towards the far side of the motherboard connections from any PS2 (keyboard and mouse) ports. Otherwise, they will line up with one of the card slots.
Newer desktop computers often have additional audio ports for surround sound. However, the pink jack for the microphone is standard. If the computer has front audio ports, you may find that the same color labels the jacks. Otherwise look closely at the icons next to the ports. These will be in addition to the back audio ports.
Laptops can have the audio ports on the front, back or side depending on the model. There will be a small icon with a stand microphone indicated for the microphone port.
If you have one of the newer USB microphones, plug it into an available USB port.
If the computer has no working audio ports, either get a USB microphone or add a sound card.
I hope this helps. If you add a comment with your computer's brand and model number, I'll try to provide the exact audio port details. (There are some computer motherboards that do not have on-board audio and you will need a sound card.)
(on Windows computers, you may have to change the default audio input. Click Start > Control Panel > Hardware and Sound > Sound > Manage Audio Devices. (for Windows 7) For other versions of Windows, you may find slightly different titles in the Control Panel.)
Jun 24, 2011 | Compaq PC Microphone (Black or Beige)...
I have HP speakers that need to be installed to my computer. There is no disk. What should I do?
What windows OS are you running? XP, Vista, 7?
Typically you can add speakers with little to no effort. You will need to check the plugs on the speakers. Is it USB? or are they small 3.5mm jacks?
Usually speakers use 3.5mm jack and depending on the type of speakers they will have either 1 connector or 6 (for 5.1 surround sound)
Once you determine what connectors your speakers have, make sure you have the matching connectors on the back of the PC. These are usually colour coded Green (for a single 2.1 connection) or multiple colours for 5.1. USB is the small rectangular connector that is short and wide.
If you have the 3.5mm connectors, just plug them in to the back of your computer and plug the speakers in to a power source and they should begin working without drivers.
If you have the USB connection you will need to determine the model of the speakers and find the driver online: http://www8.hp.com/ca/en/support-drivers.html Install the driver and then plug in the USB connection and windows should automatically install.
You could also try to let Windows update find drivers online for you.
Hope this helps.
May 13, 2011 | Computers & Internet
Brand iomega screenplay tm pro hd multimedia drive my problem is when i conect my usb cable to pc it is not been picked up in my devoices when i put in a memory stick it comes up right away
Are you using the USB 2.0 device connector (the connector right above the power connector) connection to your computer and not the USB 2.0 host port (located above the ethernet connector) ?
Dec 16, 2010 | Iomega ScreenPlay
Where does the usb cable plug in?
hi
you have to have USB port on your computer and on your printer .
9k=2q==
Nov 26, 2010 | Office Equipment & Supplies
Can i use a compaq keyboard on another brand of computer
Keyboard brand is not important. The keyboard connector is your only concern. The keyboard has either the round PS/2 connector or the flat USB connector. Therefore, the computer must have a matching port for the keyboard to work.
IMPORTANT: A PS/2 keyboard must be connected BEFORE the computer is turned on. A USB KB can be connected at any time but it may take a few seconds for the computer detects it.
Please vote for my solution if it helps.
Oct 13, 2010 | Compaq Keyboard
I just bought a netscroll optical mouse,but the
Yes you can get a ps2 connector to usb. They sell them at Radioshack and some Walmarts. What computer are you using the brand and model? The ps2 connector should fit into the one on the tower, unless its a really old computer.
Jan 15, 2010 | Genius Mouse Netscroll 110 High-Precision...
Wireless mouse and keyboard stopped working
what brand make and model ... most have a connect button on the bottom of the mouse and keyboard ... also is your connector plugged into a USB hub ... if so put it directly into a usb port on the computer ... to troubleshoot remove other usb divices and see if you can get it to work ... if its a name brand like logitech they are very good at just replacing things for free if you contact them... as long as the warr is not to far out
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
