Question about Samsung Dishwashers
What caused the dishwasher door or become so unstable and heavy when opening? It is almost like there was some sort of hydraulic issue with the door.
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
SOURCE: Kitchenaid dishwasher KUDR24SE...cannot open door
did anyone have a solution? i have the same problem.
Posted on Nov 22, 2009
mrfixit3667
  • 262 Answers
SOURCE: Fisher and Paykel dishwasher
Ok Im going on the Maytag Model # MDB7600AWB your model is missing some at the end.
If this is your Model the your door cable most likley has broken. part # 99003446
Please verify your model # from your machine looking around the door frame.
Posted on Jan 10, 2010
  • 385 Answers
SOURCE: kitchenaid dishwasher kud102crwh1 issue: door opens
Broken spring.
Posted on May 23, 2011
  • 385 Answers
SOURCE: My Dishwasher door has suddenly
The cord you refer to is part of the door spring assembly, you need to take off the bottom panel and repair or replace the door spring or cable.
Posted on Jun 04, 2011
DOOR FELL OPEN AND WON'T CLOSE, FEELS VERY HEAVY
Dishwasher doors are balanced by a set of opposing springs that, over time, can stretch and or become defective.
Get your model number and look on line on an Google search or bing. One can find a number of sources for the needed parts to repair this problem.
Aug 21, 2015 | Fagor LFA-073 IT Dishwasher
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
Frigdaire 900 series - Door has become heavy as though there is water in it. What's wrong and how do we fix it.
Hello - Sounds like the hinges may need to be adjusted or if they are too damaged, possibly replace.
Nov 02, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Water leakage from deforster
see this causes and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 27, 2012 | Dishwashers
Leak at bottom of door
see this causes and use the common sense. God bless you
Door Seal
Dispenser Seal
Water Inlet Valve
Door Latch
Door Hinges
Sep 19, 2012 | Maytag Dishwashers
Kenmore elite dishwasher leaking below washer
Door Seal
Dispenser Seal
Water Inlet Valve
Door Latch
Door Hinges
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
The dishwasher door keeps popping open
I have the same problem and it appears that everyone else who has replaced the door seal runs in top this issue. This is a new seal design that is different from the original. This new seal is obviously poorly designed is placing too much pressure on the door causing it to either not close, or open mid cycle. I am presently duck taping the door closed when running the machine in the hope that the heat cycling the new seal will eventually cause it to deform and relieve the pressure. I see that other have attempted to help the process by increasing the release pressure on the latch. This will be the last Kitchenaid large appliance I purchase.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door of dishwasher is leaking at bottom left corner.
HI. the door seal has been compromised. it could be simply farad or slightly propped open by some sort of debris as well. check the door seal for faults. replace if faults are found.
Also, make sure the door isn't mis-aligned. this will happen over time during heavy usage. re align the door if necessary.
Sep 22, 2009 | Frigidaire Dishwashers
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
13 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
