Question about Tablets & eReaders
When I power on my new nextbook8 8GB, I see the nextbook screen, but then a screen that says "No Command" is displayed.
  • Tablets & eR... Master
  • 3,320 Answers
The best solution for you would be to return it to the retailer and get a replacement that works.
Posted on May 12, 2014
How do you enable the HDMI feature on nextbook Ares 10A android tablet
By default it is enabled already. If you are trying to connect your nextbook to a TV, try this: To link to the television, simply plug the HDMI cable into the tablet and then into the TV's HDMI port. Following the connection, a HDMI notification pop-up will show on the Nextbook's screen. Select it and choose to mirror content displayed on the Nextbook screen. Next, make sure the TV is set to HDMI input, and what's on the tablet should be mirrored on the television.
Feb 07, 2017 | Nextbook Tablets & eReaders
My Nextbook model NX785QC8G freezes when you turn it on. How do I reset it to the factory settings? I have looked, but have not found a reset button.
Check http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the Volume (+) and the Power button at the same time, until you see No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until No Command shows up on your screen)
2. Release your buttons when you see the No Command appear on your screen.
3. Tap the Volume (+) once, and a blue menu will appear on your screen.
4. You will use the Volume (-) to navigate and the Power to select. Tap theVolume (-) until you highlight "Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the Volume (-) to go to the onlyYES on your screen.
6. Press your Power button to select the Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words ''Wipe Data Complete", tap your Power button once to selectReboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
Dec 29, 2015 | Nextbook Tablets & eReaders
My nextbook 7 is frozen on the home screen after i put a different charger in, what do it do ?
Try using the reset switch (a small hole in the case) put a straightened paperclip or a pin very gently through the hole until yuo meet a resistance. Press very gently and this will reset the tablet.
Jan 03, 2015 | Generic Nextbook 7" Android Tablet/ eBook...
How to fix nextbook with no command message
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Nextbook Tablets & eReaders
How to fix it, i dropped my nextbook on carpet and now nextbook turns on but nothing but green and white screen
You damaged the display screen. It needs to be replaced with a new one. It will not be a cheap repair. Estimated cost to repair is around 175.00. It will be cheaper to buy a new nextbook tablet.
Jun 08, 2014 | Tablets & eReaders
Nextbook 8 SE touch screen not as sensitive, have to tap items twice
It might need calibration. There is usually a setting in the display to calibrate the screen. Follow the instructions and see if it helps.
Jan 30, 2014 | Nextbook Premium 8 Se Android
My nextbook display is upside down,,,the power button and camra is at the bottom
If the auto rotate system is on it will switch the controls so try restarting it and then if it still does that go the the programs settings and see if u can fix it.
Jan 20, 2014 | Nextbook NEXT2 Touch Screen Android Tablet
Screen display upside down
I think you should go to the settings and make sure rotate is not turned off. Also, try to calibrate your screen again.
Jan 20, 2014 | Nextbook Tablets & eReaders
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
