Question about GE DPSR610EGWT Electric Dryer
How do I remove the top panel from a GFDS350EL1WW GE dryer?
    Sergeant:
  • 435 Answers
Where the control knobs are ? & Y
Posted on Feb 09, 2015
3 Suggested Answers
  • 32 Answers
SOURCE: clothes dryer is squealing when turned on. suspect
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to Appliancepartspros.com it item 316 they also have a diaphram.
Posted on Oct 10, 2009
SOURCE: remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Posted on Nov 05, 2012
Need to replace control panel for my GE Dryer, GFDS350EL1WW
You could try ebay, Amazon, or one of these parts dealers below.
V & V Appliance parts
Repair Clinic
Marcone Appliance parts
Or GE.com
Mar 01, 2015 | GE Dryers
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
Remove front panel ge spacemaker dryer
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How do I open the case on a GE dryer?
Of corse there is some variation among different GE models, but in general there will be one of two methods. Disconnect from power, then: 1. Open door and look for screws from top area of front panel into the dryer top to allow top to open, which in turn allows front panel to be removed. 2. If no screws, then use a putty knife to push in on the two clips which secure the top to the front panel. (right in the seam, front panel to dryer top, a couple inches in from each side.)
Sep 22, 2009 | GE DBSR453EBWW Electric Dryer
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Mar 01, 2009 | GE DVLR223 Dryers
Replace the ingniter Asm for a Ge gas dryer
I continued to search the internet and found a site that offered the info needed to open up the dryer to gain access to get to the ignitor. Buy removing 2 screws in the top of the door opening to remove the top and removing 2 screws at the top inside wall panel it removed the whole front.
Dec 27, 2008 | Dryers
GE DPSR610EGWT Electric Dryer Logo
146 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
