My whirlpool will not drain only a year and a half old
    Novelist:
  • 126 Answers
That's usually a clogged pump, Heidi. Chances are a sock or something got sucked into the pump and stopped it. I'm not familiar with your particular model but normally one has to open up the machine to clear the pump. It's not difficult with normal tools but you'll probably need some room to tip the machine. There are instructions (including videos) online to help. Good luck!
Posted on May 13, 2014
Softener reservoir doesn't drain when washing. Kenmore Elite about one and a half years old.
Possible blocking on the drain from the tray, remove the accumulated softener from the dispenser , clean and check the drain line. It can be blocked with residue or dirt.
Mar 17, 2013 | Washing Machines
My whirlpool cabrio washer has started shutting off half way through the wash cycle...won't drain and spin...could the motor be overheating or is there something else I can check?
Most likely the cycle timer needs to be replaced. it is basically a clockwork device that that has cogs attached to a spindle. if you check the schematics for your product you will find the part no. etc. any servicing of course needs to be done wit the power disconected
Jan 20, 2013 | Whirlpool WTW6400SW Cabrio Washer
After 13 minutes water runs back up drain hole thus melting ice then just before next slab drops emties drains clear new pump fitted why does this happen its a whirlpool k40 2 half y old
The drain is partially plugged... so when the water dumps right before the harvest cycle it back up in the drain...
Blow out the drain and you will be good again...
heatman101
Oct 19, 2010 | Whirlpool Refrigerators
My ten years old Whirlpool AWM285 had a problem
You need to replace the carbon brushes on the motor. If this doesn't work then you will need to replace the motor itself
May 14, 2010 | Whirlpool AWM5104/1 Front Load Washer
Whirlpool Front Loader drain pump keeps running all drain positions in cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello eastax
Welcome
My advice now a days is :
It's really not advisable to fix a dishwasher that old.
It's putting good money into bad!
Here is an article I just read that you may find interesting.
Repair or replace?
When to pull the plug on your dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems in the owner's manual and on the Web sites of many manufacturers.
Should you pay for a repair or buy a new model? The answer depends mostly on the age of your dishwasher, how much you bought it for, and the cost of the repair. Follow these guidelines from our in-house experts:
When a repair makes sense. If your dishwasher is under warranty or less than four years old , paying for a repair makes sense. Note that dishwasher under warranty might require service from a factory-authorized technician; readers have found them on a par with independent repairers.
When a repair might be a wise choice. If your dishwasher is out of warranty and is four to seven years old, it might make sense to pay for a repair. Readers paid $100 to $200 for a repair. But you might want to buy a new model even at this stage, given that today's models are quieter and have added features. They pay for them selves in only a few years due to higher energy efficiency which is another plus: Energy Star-qualified models made after April 28, 2008, are 43 percent more efficient than conventional models built before 2001 and 56 percent more efficient than those built before 1993.
When it pays to replace. The repair costs more than half the price of a comparable new dishwasher. Our data also show that it doesn't pay to fix a less-expensive dishwasher six or more years old .
Thanks to better recycling programs, less than 10 percent of a dishwasher you replace is likely to end up in a landfill.
Thank you for using our services to advice you.
Please remember to leave a rating!
Oct 05, 2008 | Whirlpool Dishwashers
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
