Question about Sylvania Sdvd9000b2/6 - 9-inch Portable Dvd Player With Car Bag/kit,
Why does main screen say open? - Sylvania Sdvd9000b2/6 - 9-inch Portable Dvd Player With Car Bag/kit,
    Problem Solver:
  • 17 Answers
The reason why it says "open" is that the DVD "door" switch, sensing if it closed/open, is either broken or one of the leads/wires to/from it is broken off at the soldering. Repair/replace the switch or re-solder the wire. I just repaired one unit where the switch had come apart; switch is made of 4 parts, the main part is soldered to the circuit board, then there is a spring, a plunger and a snap retainer which snaps close with the main body holding the spring and plunger together. The snap retainer comes off the main body vary easy since it is made too thin. It is easy to reassemble and then wrap a piece of tape around as to hold the retainer in place.
Posted on Apr 25, 2015
    Sergeant:
  • 258 Answers
Explain further what do you mean say open.
This is the most common problem with tablets - its usually corrupt bootloader or OS and can be a nightmare to repair.
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up. Its actually a disgrace and I have been repairing computers and latterly tablets for the last 30 years and it is by far the most common issue with any tablet except Apple - there is a reason they are so expensive - lol
Posted on May 13, 2014
My exhibit touch screen wont let me swipe screen to open
If you can get into the main menu go to settings Spanner n screwdriver symbol > security > screen lock and follow the directs on screen. If not found under security it should be under display/screen settings.
If however you cannot access the main menu return to supplier/shop
Jul 22, 2014 | Samsung Cell Phones
The media player stuck on main screen
Open up the Widget bar and drag the media player back into it, then close the widget scroll bar.
Jul 17, 2009 | Samsung S8300 Ultra Touch platinium-red...
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Lg Dare phone
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Nov 16, 2008 | LG RUMOR Cellular Phone
SanDisk Sansa e260 Rhapsody 4.0 GB
win open i see load main image faild Switch to Recovery mode and do not open and do not show in the vomputer
Jul 24, 2008 | SanDisk Sansa e250 MP3 Player
Main screen not desplaying when I open up my Nokia 6131
Try turning the phone on with the flip screen open. Do it a couple of times if it doesn't work the first time.
Apr 28, 2008 | Nokia 6131 Cellular Phone
Blank Screen on my main display
You need to chance the strip in side the mobile. or else we need to change the display.
Feb 25, 2008 | Nokia 7390 Cellular Phone
My iphone doesnt want to open to the main screen
do a soft reset, push the power button and the sleep button on top of the phone at the same time for about 10 seconds until the apple sign shows up
Feb 18, 2008 | Apple iPhone Smartphone
Nokia 6111 screen replacement
check out the connectivity with the main chip with the screen and than try to find out the screws if found than open it up and be careful while opening it cause it may damage ur main chip as well,
Oct 18, 2007 | Nokia 6111 Cellular Phone
Sylvania Sdvd9000b2/6 - 9-inch Portable Dvd Player With Car Bag/kit, Logo
78 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
