Question about Avanti Freezers
I bought a used avanti freezer model # cf2010 and it didnt come with a drain plug. Where can I get one?
Model number cf2010. i need to buy a drain plug, biut cannot find one anywhere.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Most appliance stores can order you one , if you have your model # and serial number,, or you can do a search on www.amazon.com
Posted on May 13, 2014
Drain is clear but ice stilll forming in bottom of freezer
Use a steamer to blast the drain clear... sometimes you need to install what is called a heat probe that feeds into the drain tube to keep it from freezing over... Help Me Find My Model Number RepairClinic com
Oct 04, 2016 | Freezers
I bought a chest freezer and it didnt have a basket so I bought a basket now I need to by extension handles but I cant work how the attach to the basket. it is a fisher and pyckel model h220
if you got the right basket the handles are already attached
they are either folded into the basket or lift up on the outside to sit on the edge of the freezer
Aug 15, 2016 | Fisher Freezers
Freezer not freezing after electric plug went out. Plug was out for a day or two before I noticed it. When I plugged freezer back up, will not get cold.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 17, 2010 | Avanti 3.4 cu. ft. / 96 liter Chest...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
I bought a used model MFC05M3BW5 chest freezer. I
Please see attached link for more info, but it appears as though your model has both an internal and external drain plug. Hope this helps
http://www.youserguide.com/wiki/Electrolux_216657700en-007
Sep 30, 2009 | Freezers
Need defrost element for 1996 Kelvinator Freezer
Fixya is unable to suggest sources for a Kelvinator defrost element.
Mar 04, 2018 | Kelvinator 12 cu. ft. / 340 liter Chest...
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Jun 30, 2007 | Avanti 1.4 cu. ft. Chest Freezer...
Freezers Logo
100 people viewed this question
Top Avanti Freezers Experts
Dennis Boxerman
tom wright
tom wright
richie46
Are you an Avanti Freezer Expert? Answer questions, earn points and help others
