Question about Electric Garden
Where can we get a missing pin that locks in the attachment to the drive sproket on the frame?
This is for a 4 in 1 yardworks lawn maintenance machine
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
"R" pins and Clevis pins can be gotten at any tractor place or Tractor Supply Warehouse.
Home depot may even carry a small selection.
Posted on May 12, 2014
Yardworks. Why is drive not moving?
Put machine up on it's auger and take off bottom cover. All the guts are under that cover. you should be able to see and understand how the chain drives the wheels. Some machines have Sheer pins ( a 1/4" bolt) on the Drive axle. Look for it by the chain sprocket
Jan 16, 2016 | Garden
Poulan Pro PB195H42LT Product # 960420107-00 Purchased April 2010a Looking for a photo for the drive assembly for this lawn tractor. The break down in the part's manual doesn't show the spring...
Try using a vice grip to attach spring. Look for wear marks where paint is missing from frame to help locate spring position. Hope this helps.
May 21, 2014 | Garden
Attach snowblower yardman lawn tractor
most likely not unless...
Oct 03, 2013 | Garden
Need to replace main drive belt for sickle bar
Instructions
Put on your work gloves. Check the frame size for your mower. It will either be a 56-inch frame mower or a 76-inch frame mower. When you have determined the frame size, adjust the tractor's rear wheels to the mower's frame size. For 56-inch frames, adjust the rear tractor wheels to 56-inch centers or less. The same rule applies for 76-inch frames.
Back the tractor into a position where you can align its left lower link to the mower's lift link pin. Attach these two parts together and secure the connection with the tractor linchpin.
Roll the tractor and adjust the leveling crank until the tractor's right lower link can be attached to the right link pin on the mower. Use the tractor linch pin to secure the connection.
Attach the upper link from the mower to the lower hole in the tractor rocker arm by using the link pin.
Start the tractor. Using the hydraulic control lever, lift the mower frame assembly slightly and move the mower to the left to allow attachment of the left stabilizer. Place the stabilizer guide under the tractor's left lift link. Position the clamp over the link and tighten the nut firmly
Depending on the tractor type, install the clamp plate or push rod anchor assembly onto the left lower link. Install the push rod on either the clamp plate or anchor assembly.
Shift the mower assembly to the right to attach the right stabilizer. Place the stabilizer guide under the tractor's right lift link. Position the clamp over the link and tighten the nut firmly.
Raise the mower using the hydraulic control, then attach the mower lift spring to the spring links with the pins that have been provided. Lower the mower assembly and turn off the engine.
Remove the tractor power takeoff (PTO) cap and connect the splined end of the mower's drive shaft to the PTO shaft. Secure the connection with the snap coupler found on the yoke.
Rotate the leveling crank to lower the frame, ensuring that it is parallel to the ground. Use the leveling crank lock to secure the crank lever.
Jul 15, 2012 | Vacuums
Footpeg spins around
Hi Cher1029, this is a moderately easy fix but you are going to need a service manual for torque specifications and clarification please visit website below for $6.50 download.
1. Remove exhaust system.
2. Remove the screw and clip to free the brake line from the sproket cover.
3. Remove the two socket head screws and lock washers to free the rear brake master cylinder from the sproket cover.
4. Loosen the locknut and turn the brake push rod at the flats untill it is free of the rod end.
5. Remove the three sproket cover screws and washers. As a single assembly, remove the sprocket cover, footrest mount, rear brake pedal, and master cylinder stiffner.
6. Remove cotter pin and nut from footrest mount. Use blue Lock Tite on threads and torque footrest mounting nut to 40 ft lbs. replace cotter pin and assemble in reverse order. Good luck and have nice day.Harley Davidson Manuals Mark Workshop
Jan 28, 2012 | 2001 Harley Davidson XL Sportster 883
My troy bilt snowblower 4510 - the drive wheels have no power
This machine has pins to hold the wheels to the axle. The pins may be out and allow for a "free wheel " mode. Check that these pins are locking the axle to the wheel. If so the problem is between the wheels and the drive belt.
I recommend using a local lawn mower shop like arco lawn equipment Joe
Feb 11, 2011 | Troy Garden
... I cannot remove the right footpeg post from
Hi Dtravis13, this is a moderately easy fix but you are going to need a service manual for torque specifications and clarification please visit website below for $6.50 download.
May 24, 2010 | 2001 Harley Davidson XL Sportster 883
Missing INstructions for YardWorks water timer CT 59-3213-8
PDF can be found here: http://www.orbitonline.com/lib/media/62032-24ErE_001098.pdf
Jun 23, 2009 | Garden
Garden Logo
48 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
Mike
Are you an Electric Garden Expert? Answer questions, earn points and help others
