Question about Zapco Reference 750 Car Audio Amplifier
How do i reset kicker kx 850.2 from protect mode ?
Please help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Zapco Master
  • 2,226 Answers
If it goes into protect and your speakers and wires are good, chances are you have bad output transistors that will need to be replaces.
Posted on May 16, 2014
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
Turns on but heats up and goes into protection
Capital Audio & Electronics Repair in Tallahassee,FL we repair all namebrands & all models--850-339-1130 lowest repair prices in tri-state area
Mar 14, 2010 | Car Audio & Video
Have a kicker 350 4 played to loud stuck on protection
contact eric @ Capital Audio & Electronics Repair 850-339-1130 we repair all brands & all models
Mar 12, 2010 | Kicker KX350.4 Reed Multi-Channel Amp -...
My kicker kx 1200.1 keep clicking to protection mode back and forth when it power. There is a clicking sound comming from the amp...is it a major problem to fix? This just start happening when i was listen...
Look for a frayed speaker wires. Look everywhere. Start where you can see and then look under carpet, under seats, trunk and everywhere wires go throgh a hole in steel frame. Any minor connection between the two speaker wires will cause high-power systems to go into protection mode. Wires can be damaged by long-term vibrations of your car, people stepping on badly placed wires under carpet, moving seats (when adjusted) or even rodents bitting on the wiring. Look closely and you will normally find it. Also look closely where you connect your speaker wires to the amp. One small strand of wire jumping across to another terminal will cause a short and cause protection mode.
Nov 19, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
I've been running a kicker kx 800.2 and it has worked until now
Hello highryguy420,
It sounds like one or more of the output components is failing on the amp. You can contact Kicker support directly for instructions to return the amp for repair: support@kicker.com . Alternatively, if you have a local car audio shop that does component level repairs, they could perhaps save you some money and time.
Hope this helps.
Jul 14, 2009 | Kicker KX800.2 Car Audio Amplifier
The protection light goes on and off over and over again
check positive cable for short like rubbing where u ran into car/from battery check ground cable make sure tight connections then try just 1 speaker at a time if ones blown or on its way out may put in protection mode if no change replace rca cables
Mar 31, 2009 | Kicker KX Series 04KX400.1 400w RMS...
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
Zapco Reference 750 Car Audio Amplifier Logo
125 people viewed this question
Top Zapco Car Audio & Video Experts
xxxxxx xxx
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
