Question about HP LaserJet 3390 Printer
Hp laserjet 3390 print ip number - HP LaserJet 3390 Printer
SOURCE: Refilling of Laserjet Cartridge
dear sir good morning
sir please send a soulation for refilling of hp laserjet 1020 prineter cartridge with graphic soluation. request send immeditely in my E-Mail ID
shaan_rao@rediffmail.com
Posted on Jul 17, 2008
SOURCE: HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
Posted on Sep 17, 2008
jonb3838
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Posted on Feb 12, 2009
shadiabed
  • 72 Answers
SOURCE: HP LJ printer printing slowly
try to change the driver on the network definition
Posted on Jan 05, 2010
  • 217 Answers
SOURCE: HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Posted on Apr 05, 2010
How to print envelop on HP 3390
you would be better using sticker sheets.
see for an example
http://www.officeworks.com.au/shop/officeworks/c/office-supplies/labels/address-labels
your local office supply shop would have something similar
Some labels have downloadable templates to make it easy to line up the addresses to the laser label sheets
Trying to print on the envelope could cause jams inside the printer
Aug 13, 2016 | HP LaserJet 3390 Printer
How to get configuration page from and HP 3390
To print the configuration page
1. Press "Menu".
2. Use the "<" or the ">" button to find "Reports", and then press OK .
3. Use the "<" or the ">" button to find "Config report", and then press OK .
Jul 11, 2011 | HP LaserJet 3390 Printer
Hi, I am trying to print with my HP LaserJet 3390 and it says 'No paper pickup'. Can you help? Regards, Peter G.
Try to perform the following steps in the mentioned order:
1. Verify that the media was inserted far enough into the input tray. In tray 2 (HP LaserJet 3390/3392 all-in-one), verify that the paper-length guide is in the correct position for the media size that you are using.
2. Reload the media in the input tray and press c00597632.gif to continue the job.
May 23, 2011 | HP LaserJet 3390 Printer
Hp 3390 work with w7 64x in scan mode ???
Your 3390 will only scan by using the Windows scanning software, the HP solutions do not work on Windows 7.
This is how you can scan from your 3390, assuming you have been able to get it working for printing on your system.
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
When printing from an HP Laserjet 3390 all in one printer, getting a thick black line down one side of the paper.
if it is uniform, replace the cartridge
if it is not uniform, you have to replace the fuser asembly
Mar 16, 2010 | HP LaserJet 3390 All-In-One Printer
Error messages 10 1000supply error for printer 3390
This error implies the print cartridge is not installed correctly.
The steps to resolve the issue: 1.Reinstall print cartridge. 2. Power cycle all-in-one. 3. If the problem is not solved, replace the cartridge.
Hope this helps!
Aug 31, 2009 | HP LaserJet 3390 All-In-One Printer
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Printing problems
Hi, Is this happening on the flatbed or the ADF?
Dec 03, 2007 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 3390 Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
