Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
I am downloading from bitcomet. My listening port is block and I need to configure my NAT setting on my Netgear router WGR614. How do I do that? What do I put as my start port, end port and IP?
  • 1,272 Answers
Hi, follow the steps as mentioned in the link below to configure settings on the NETGEAR
http://www.portforward.com/english/routers/port_forwarding/Netgear/WGR614v7/BitComet.htm
Rate it, if it helps.
Posted on Jun 23, 2009
How do I change the NAT type on my Netgear WGR614 v6 router from strict to open?
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on NAT and then port forwarding then open port tcp and udp which you want then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 19, 2010 | NetGear WGR614 Wireless Router
Just connected talktalk router to pc but when i go onto bitcomet to download music,i seem to be blocked.do i still need a modem.
R U the Administrator of the WRT54G Router If not then ask to ur Administrator to unblock the site preference
then go to the WRT54G Router configuration page & Check for Access Restriction>Internet Access Policy
modification.
Apr 13, 2010 | Linksys Wireless-G WRT54G Router
Listen Port of TCP: 2869 (Blocked by Firewall/Router) how do i change nat router settings?im blocked when usin bitcomet software
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
Oct 08, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do i open nat ports on a netgear WGR614
u should open on ur bowser
http://192.168.0.1/
then configure ur router ports
Jun 17, 2009 | NetGear WGR614 Wireless Router
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
http://portforward.com/
May 10, 2009 | Computers & Internet
Bitcomet and Belkin router
To fix this issue all you have to do is,You should open the bitcomet downloader portnumbers on the belkin router,you need to open default page by typing 192.168.2.1 in address bar.
And also i would like suggest you to disable firewall on router and check for firmware update... It may be quiet difficult for you to do all this.please call tollfree number"belkin" and ask them to change these settings which i have mentioned.and it will definitely work.....
.....Hope this is help full for you
Apr 14, 2009 | Belkin (F5D7230-4) Router (587009)
Firewall and Nat router configuration for BitComet
Has it ever worked? If not, run the disc that came with it. And what yellow light exactly do you speak of? Are the proper cables connected to the proper ports?
Mar 29, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Listenning port bit comet
BitComet requires you to be able to receive incoming connections. If you're behind a NAT router but don't have port forwarding configured properly, incoming connections will be stopped by your router (won't get to your computer).You need to configure port forwarding, so your router knows that the incoming connections are for BitComet and will be allowed through (= forwarded) to your computer.
There are several versions of your router:
DSL-2640B, DSL-2640Bv2,...
Go here, scroll (almost all the way down) and find your router model.
On the next page, skip the advertisement (upper right corner) and look for BitComet.
Simply follow the instructions on that page - they are precise and correct.
In general: You can use ANY port, but I would prefer a listen port between 49152 and 65534 because they're classed as "Dynamic and/or Private Ports" by IANA, so nothing else should be using them by default and they're not the standard ones blocked by ISP's or trackers, but - as I said - you can enter any other port you wish.
If you have any more questions, just come back and let me know - I'm happy to help.
Good luck & thanks for rating!
Mar 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Jul 15, 2008 | NetGear WGR614 Wireless Router
Online and downloading is very slow
Go into your router settings by opening your internet browser, clicking in the URL address bar, and typing in the router's domain address, either 192.168.0.1, or 192.168.1.1 or 192.168.2.1, and Enable UPnP.
This is known as port forwarding.
Good Luck
Chris (ziraffa)
Jul 06, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
503 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
