Question about Anne Klein 10 6927SVSV Watch for Women
Where can I get a replacement band for this watch?
The inside of the band has lost its finish and is tarnished.
Missing screw to hold band together need replacement
Most jewelry stores--or even jewelry counters in department and discount stores like Walmart--keep a supply of replacement screws for when one is lost while changing a watch band. Ask around, show them your watch, and you may even get the right screw for free!
May 06, 2011 | Field and Stream F187GWBS e by Field &...
A pin popped out of my band and was lost. In addition, the curved piece that blends the band to the bezel of the watch was lost and not to be found. I can't locate a replacement band or replacement part...
Replacing the spring pin is not a problem, however for the band to look as it did originally, the end piece, or end tab - which is now missing, must be replaced. These parts are generally proprietary. You can order one from your local Certified Master Horologist.
You may also consider contacting Luminox. Sometimes, the manufacturers run out of these parts and the whole band must be ordered because that is all that is available.
Contact Luminox Repair Center at 401?946?0920.
Feb 04, 2011 | Luminox 3100 Carbon/ Steel Band Watch
My band has broken, and I've lost two of the links. Can I get replacement links or a replacement band?
mcdevito75 here, Look for a small watch repair shop in your area for replacement.
Jun 29, 2010 | ESQ 7300698 Watch
It's too small on my wrist I have the extra bands but I don't know how to add them
you will need sharp needle nose pliers and a small ering pin (the part that goes thru the ear) use your needle nose pliers and grabing the ear pin pushe the pin that holds one of your wrist band then finish pulling the pin with the needle nose pliers all the way add the extra band and insert the pin with your fingers first then finish with pliers
Oct 26, 2009 | Kenneth Cole KC3315 Wrist Watch
10L02 Wittnauer watch~need band screws that connect link to link
If you can get to a watchmaker or even one of those watck "kiosks" where they mostly replace batteries or even a jeweller they may have what you need.
Jul 18, 2009 | Watches
Kenneth Cole Watch 3574 pin in length has broken
are you talking about the band pins or the lug pins? most watch repair stations will have lugs and pins, and will replace for about $5...any more and you will be getting ripped off. Lug pins are a pain and unless you have the proper lug tools, you can end up scratching the finish of the watch...be careful!
Jul 06, 2009 | Kenneth Cole KC1169 Wrist Watch
Lost part of Skagen band
this piece is actually only 4.00 from skagen try this website
http://www.skagen.com/service/orderWatchBandParts.fx
Jan 24, 2009 | Skagen 355LGSC Wrist Watch
Lost screw to secure watch band on Skagen 355LGSC
You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
Find your nearest watchmaker and ask for help.
Dec 22, 2008 | Skagen 355LGSC Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
I have broken my wrist band for my watch.....
You should be able to purchase a replacement band at any local watch dealer. They will need to measure the width of the band where it connects to the watch, and then can offer you a variety of styles to choose from for a nominal cost.
Mar 25, 2007 | Vanceur Royal Castle CG35S Wrist Watch
Anne Klein 10 6927SVSV Watch for Women Logo
27 people viewed this question
Top Anne Klein Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
