Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Change language on mfc 255cw - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
GERMAN TO ENGLISH ON MFC
Hello, you can try this simple steps configure your language in any language you want; english, german or japanese or even more! And this is the steps, kindly follow it thoroughly to changed it with ease;
1. Open your phone.
2. Tap Menu.
3. Tap Configure or Settings. (a wrench icon)
4. Tap Phone. (a phone icon)
5. Tap Language Settings.
6. Tap Phone Language.
7. Tap the language you want.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 04, 2014 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Brother MFC-295CN printer was stored for 2 years. Black ink won't print now no matter if brand new cartridge.
this work for me with a mfc 255cw. why it works I don't know but I will continue to use this setting. thank you
Jun 05, 2012 | Brother MFC Office Equipment & Supplies
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
Change language
refer manual goto printer's setup function and change language
May 24, 2010 | Brother Multi-Function Center MFC-240C...
I already downloaded the drivers needed at brother.com, but still can't install the printer MFC-255cw) on windows7
It is possible that you have the wrong driver package.
Here is the link you need to download and install the MFC-255CW on Windows 7
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/004000/dlf004002.html?reg=us&c=ca&lang=en&prod=mfc255cw_all&type2=1&os=92&flang=8&dlid=dlf004002
Make sure that you choose "save" to download the file; I recommend saving it to your desktop.
Once the download is finished, you will want to double click to run and decompress the file.
You should now have a folder called "mflpro_c1"
Open that folder and then open the folder corresponding to your printer (mfc-255CW)
Now you will see multiple folders with a setup dile at the bottom, run the setup.
If the printer is to be connected wireless, please make sur the wireless connection is completed before installing the software.
Thanks,
Pat
Apr 09, 2010 | Brother HL-2040 Laser Printer
Error message "Unable to Init"
This is a mechanical problem.
The machine is discontrinued, not worth repairing.
If you like this model you can look for the MFC-255CW on sale somewhere for cheaper then repairing.
Mar 24, 2010 | Brother MFC 210C All-In-One InkJet Printer
How do you use a memory stick on the MFC-255cw printer
just plug it in the machine but if the machine cannot see the files it will not print that machine will only see the tiff jpg and maybe pdf files.
Oct 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
29 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
