Question about Radio Communications
How do i pair my hs-bt102-bk to my lg p705g - Radio Communications
  • 5,481 Answers
First make sure that the phone and the headset are fully charged. Turn on the P705F and enable Bluetooth for the phone. Touch the Apps button and look for the Apps tab. Go to Settings and then find the Wireless and Networks section. Set Bluetooth to On. With the headset off, press and hold the answer button (on the back) for 7+ seconds and the red and blue lights blink alternately. Set your phone to look for available Bluetooth devices by tapping the Bluetooth menu. If needed, click on Search for devices. Find the headphones in the list. Type in the code 0000. If the blue light blinks 3 times and then once every 7seconds, it's paired correctly. If that fails, try again from pressing the Answer button.
I hope this helps.
Posted on May 12, 2014
Need free code for a lg -p705g
network unlock lg-p705g
Feb 05, 2013 | Cell Phones
I can't sync my LG CE110 with my HS850 bluetooth
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Mar 11, 2009 | LG CE110 Cellular Phone
Wire color codes for '95 Ford stereo
i will post 96 Taurus. Not sure if the same as 95. you did not say which radio you have, base or premium.
please rate as fixya if this is what you need
Base Audio System With/Without Cassette Player
Pin Number Circuit Circuit Function 1 729 (R/W) Battery Feed 2 57 (BK) Power Ground 3 434 (LB/BK) Pulse Width Modulated Illumination Signal (Analog) from Headlamp Switch 4 1002 (BK/PK) IGN/RUN/ACC 5 640 (R/Y) IGN/RUN/START 6 694 (BK/LG) Logic Ground 7 — Not Used 8 — Not Used
Pin Number Circuit Circuit Function 1 593 (DB/W) Tape Audio RH + 2 594 (GY) Tape Audio RH - 3 57 (BK) Ground 4 833 (T) Audio Communications Protocol B 5 1068 (LG/BK) Audio system ON 6 723 (GY/R) Phone Wake Up 7 — Not Used 8 59 (DG/P) Rear Defrost 9 503 (BR/LG) Tape Audio LH + 10 504 (W/PK) Tape Audio LH - 11 — Not Used 12 832 (LB/PK) Audio Communications Protocol A 13 — Not Used 14 — Not Used 15 1010 (DB/O) Heated Back Window 16 — Not Used
Pin Number Circuit Circuit Function 1 803 (BK/PK) RH Rear Speaker (-) 2 802 (O/R) RH Rear Speaker (+) 3 811 (DG/O) RH Front Speaker (-) 4 805 (W/LG) RH Front Speaker (+) 5 801 (T/Y) LH Rear Speaker (-) 6 800 (GY/LB) LH Rear Speaker (+) 7 813 (LB/W) LH Front Speaker (-) 8 804 (O/LG) LH Front Speaker (+) 9 — Not Used 10 747 (R/PK) Power Antenna (Up Signal) 11 — Not Used 12 694 (BK/LG) Ground 13 694 (BK/LG) Ground 14 720 (R/Y) B+ Supply
Mar 06, 2009 | 1995 Ford Taurus
Need wireing schamatic for 1988 ford ranger (audio)
LG/Y --Power
Y/BK --Ignition
BK -- Ground
LB/R -- Illumination (+)
Or/Bk -- Illumination (-)
DG/O -- Right door speaker (-)
W/LG -- Right Door Speaker (+)
O/LG -- Left Door Speaker (-)
LB/W -- Left Door Speaker (+)
If it has rear speakers:
O/R -- Right Rear Speaker (+)
Bk/W -- Right Rear Speaker (-)
PK/LG -- Left Rear Speaker (+)
T/Y -- Left Rear Speaker (-)
Hope this helps
Feb 24, 2009 | 1988 Ford Ranger
HFBLU-LT100 pairing a second phone
Canadian Tire's HFBLU-LT100 (BK-600) won't connect to my SPH-m300 Samsung phone but I entry of the passcode (0000) about 20 times before it connect successfully.
Jul 31, 2008 | Cellular Innovations HFBLU-CX1 Wireless...
Hs801
how can i connect hs 801 bluetooth with mobile how it become on pairing mode
May 23, 2008 | Motorola Mobility HS801 Consumer Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
