Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Need to know correct color wiring from goodman model gph1330h41 with heat kit to honeywell model th5220d thermostat. Thanks
    Master:
  • 259 Answers
Here is the wiring from man. f you have trouble figuring out the programing or what terminals to use in thermostat there is an help phone number. Be shure to turn off all power to unit and thermostat, remove batteries from thermostat.
Need to know correct color wiring from goodman mod - jl+ax8un4pr7j8pz3ifmkacgi5aaaaaelftksuqmcc
Posted on May 14, 2014
  • 833 Answers
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Posted on Nov 13, 2008
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
SOURCE: honeywell thermostat
I had the same problem and decided to take a chance and call honeywell customer support. I am shocked, they solved my problem! At least in my situation we found that the blue wire ran the compressor. Instead of hooking up to "blue" on the thermostat, we hooked it up to "white." It works wonderfully now.
Posted on Apr 25, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
I have a Goodman central HVAC system (forced gas air and AC). I replaced the old CHT18-60 thermostat with a Honeywell RTH2310. Now the heat and fan stays on constantly (regardless if in the programed mode...
I checked the model #'s and they should interchange just fine. Double check your wiring. On the thermostat Red to Rc (which should also be jumped to Rh), White to W, Green to G, and Yellow to Y. Move T-stat controls from current position to oposite end and back to what you want to run ie. A/C if thats what you want. Move fan control to on and back to auto. (I find this eliminates some close but not quite right settings). This should work. If not look in furnace to verify how it is wired. Any colors that do not match the above will be your corrective action to do at the thermostat. if necessary change t-stat wires at t-stat to match what is in the furnace.
Dec 28, 2010 | Honeywell Focus 6300B 5-2 Days...
Bought a honeywell thermostat and we are trying to wire it up
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you.
Dec 20, 2010 | Goodman Heating & Cooling
I installed a Honeywell TH5220d 1029 thermostat on a American Standard AC/Heat pump and the install and setup went fine. It cooles for about and hour and quit. I found the 5 amp fuse at the furnace...
Red wire to R on thermostat red on furnace and red on heat pump Same with white except w1 on thermostat. Blue to common on thermostat common of furnace (probably brown but will be marked) and blue to common on heat pump. yellow to Y on thermostat and straight to heat pump. Orange to O on thermostat and straight to heat pump. If wired correctly with no shorts fuse problem should be solved. commonly people leave enough wire exposed inside the t-stat for wires to short together. This will blow the fuse. Hope this helps. I understand the frustration.
Jun 27, 2010 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
I have 2 Honeywell TH5220D thermostats installed in my house & want to replace 1 with Honeywell TH6220D 1028. The wiring on the existing thermostats is as follows (a jumper wire from Y2 to W2,1 wire...
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Apr 06, 2010 | Honeywell Electronic Programmable...
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
Nov 19, 2008 | Heating & Cooling
My heat wont turn off
if you have an emergency heat position we will assume you've got a heat pump. If you do not have a heat pump you have the wrong thermostat for your application. Need model of this thermostat, wire colors, termiation points (what terminal designator they are connected to), and if you have it where they were and the model of the last thermostat that worked correctly
Nov 17, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
77 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
