How to wire a coleman mack themostat part no. AP7862
Wiring specifications
3 Suggested Answers
SOURCE: need wiring diagram for transformer and themostat
http://www.nordyne.com/Literature/7083400.pdf
There is a manual it has a diagram inside. http://www.nordyne.com/Literature/708340b.pdf
That's all the info i could find mentioned at all on the net, I did exhaustive searching....
Posted on May 15, 2010
heatman101
  • 43501 Answers
SOURCE: coleman mach3 wireing diagram diagram
Hi, Yes, but you need to know which wires do not need to be hooked up...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
How do I know which sides to hook up the four sets of wires that go to the manifold on my Pentair mastertemp 250. Are they interchangeable? One purple set one red set one orange set one brown set.
Absolutely not, they are not interchangeable! Each set of wires, go to a specific sensor or switch. The opposite end of that wire goes to an electronic circuit board with specific logic. It is in constant communication and or waiting for communication/confirmation, from that specific switch or sensor, so that a specific action can be taken for a specific situation, all based on that specific sensor or switch that it is connected to. So therefore do not rearrange the wires.
purple wires usually go onto a pressure switch. Red wires will normally go on to the automatic gas shut off switch, or AFS.
there are usually two sets of two wires for the high limits, and they are colored orange. Because there are two high limits.
Brown wire, I'm not sure of? I don't remember any brown wires on a master temp. Is it possible that the brown wire that you see, has discolored and it was an orange wire, or a set of orange wires previously?
May 21, 2015 | Pentair 460732 MasterTemp Heater 250BTU ...
Wire a aftermarket stereo to 1997 Lincoln town car without using wiring harness
Why would you want to do that? Go to crutchfield.com and buy a harness for $25 With or without JBL Sysyem?
http://www.crutchfield.com/g_103000/Vehicle-specific-Wiring-Harnesses.html?tp=2977 Vehicle specific Wiring Harnesses
Jan 30, 2015 | 1997 Lincoln Town Car
How to fit a westfalia specific towbar wiring kit to a bmw e 60?
Send an email to me at tfhodd@gmail.com and I will send you 2 installation PDF's for a 7 pin and 13 pin Jaeger cable. Please be aware that you do need a car specific cable set for a BMW E-60. This cable set includes CAN-bus modules. You cannot simply make taps on existing wiring as this will impact the BMW's fault diagnosis system.
May 04, 2014 | 2009 BMW 520d
I'm not sure which wires are for the power to my audio in my 2002 Nissan Xtrail
i found recently that the wiring harness kit that you can buy at walmart for ten dollars has the specific wire labels by color code and location listed and very easy to read. The manual was very specific to my truck and worked great.
Dec 11, 2012 | Cars & Trucks
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
What are the electrical readings on the throttle positioning sensor
The throttle position sensor has both an idle contact switch and a basic 3 wire potentiometer that measures throttle angle opening. The idle switch and the throttle potentiometer share a ground wire.
To test the sensor first you have to verify that the wiring is intact by
1. Disconect the sensor and with a volt meter check the 4 wires. I have attached a wire diagram and picture of the pin layout to make it easy for you.
Pin 1 ( Yellow wire) is the PCM reference voltage. Specification is 5V
Pin 2 ( Red and Green wire) is the signal wire for the TPS. Specification is 5V
Pin 3 (Blue and white wire) is the idle switch. Specification 5V. Please note that this circuit is not actually used by this year Sedona so some vehicles are missing the wire.
Pin 4 (Black and yellow wire) is the ground. Specification: continuity to ground ( less than 1 ohm)
If the voltages are correct next you want to check the sensor.
1. Connect the throttle sensor connector.
2. Key on engine off
3.With a voltmeter measure terminal 2 of the sensor with the throttle closed, Specification is .2 to.4 volts.
4. With ta voltmeter monitor terminal 2 with the throttle fully open.The specification on terminal 2 is 4 to 4.4 V.
5. Slowly open and close the throttle while monitoring terminal 2 and make sure you have a smoot increase and decrease in voltage as the throttle is moved from close to open throttle and returned to idle.
Jan 12, 2011 | 2005 Kia Sedona
Whitch wires go to the coil. Witch one of them are pos. & neg . i have a street & trail honda size 500cc
http://www.cmsnl.com/honda-xr500_model380/
Try this link, it has exploded views of all the bike in specific sections. (This link is currentley on an XR 500cc Trail bike), go to header and click <<motorcycles>> then choose your specific model and year.
Most era specific bikes will have the same wiring in and around coil/cdi etc. Most annual changes were lighting and such. In most cases, all wires exiting the crankcase go to specific same color male/female connections for the CDI and Regulator/Rectifier, with the extra wires being the coils. The earth wire will have either a screw down ring end or fit the only corresponding male or female connection. The other generally non black wire will have its corresponding connection. Hope these help, Cheers.
May 20, 2010 | Motorcycles
I need to know which color wires are specifically for which speakers
The 2 white wires are for the front left, they gray wires are for the front right, the 2 purple/violet wires are for right rear speaker and the 2 green wires are for the left rear speaker.
May 19, 2010 | JVC KD-G120 CD Player
Power wire for brake stop switch? I'm adding an electric brake controll and need to know which wire has power when the brakes are pushed? There's about6 going into switch
to do this you need a twelve volt tester ground one of tester and test the wire on brake switch and u will find the right wire
Jul 07, 2009 | 1999 Jeep Grand Cherokee
Wiring up thermostat on split heat/cool system
you have stated no problem .only that you are wiring up a stat. thanks for sharing but what specifically are you looking for a stat ? a wiring diagram? what?is it a straight cool ? a heat pump? be specific please .
Oct 11, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
