What Bosch wff 1201. I think the heating element may be damaged. It hasn't gone open circuit but what is it's impedence supposed to be?
  • 1,140 Answers
As long as there is no break in the heater element, there is no problem with the heater element. The thermostat is bad if you are not getting the proper amount of heat.
Posted on May 29, 2014
JR JR
  • 116 Answers
SOURCE: washing machine: water level is high
PRESSURE MAY HAVE KINK OR DEFECTIVE
Posted on Nov 30, 2008
SOURCE: instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
Posted on May 23, 2009
  • 25 Answers
SOURCE: Element Needs changing Bosch WFO2466
you should never have to remove drum to replace element. not familiar with this machine take back off and have a look or it will be at the front of machine
Posted on Jun 24, 2009
Macmarkus
  • 2605 Answers
SOURCE: Hi,
First of all, if you have checked the element with a meter an it indicates it's "open" then yes it is faulty.
Second, it can be a challenge to change the element and you might want to consider an expert.
**unplug the unit from the power source**
Note where the wires are attached to the heater and remove them. Now you'll see there is a single nut in the center, likely about a 5/16 or 3/8, or similar in metric. Once that nut is off, the heater should pull straight back and out. It may need some firm pulling. The tricky part is lining it up properly when re-installing it as to get in the bracket which keeps it from contacting the basket.
You can do a trial run if you're not sure, If once you start you think it isn't going well, phone a certified tech.
Hope that helps.
good Luck :)
Posted on Oct 29, 2009
Testimonial: "Perfect response and answer I was looking for. Many Thanks"
  • 1738 Answers
SOURCE: spin cycle does not operate
Your clutch on your motor is not working. Your clutch on your motor controls how the motor either spins or agitate.
Posted on Dec 15, 2009
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wff 1201 Circuit breaker trips
they are worth repairing
it depends on the problem
Feb 11, 2014 | Bosch Washing Machines
I have a Bosch Nexxt 500 series dryer. It runs but has no heat. I have cleaned the exhaust system thoroughly and cleaned the heat sensor. Now I think the problem may be in the heating element? Is this a...
probably not the heating element but one of the toc's has gone(temperature overload cut out)if you are handy with a multimeter test it and if it shows the symbol 'ol' youll know which one is gone
Aug 18, 2013 | Bosch Dryers
No heat cleaned all filters
Either the element has failed, or one of the thermal button fuses has failed open circuit. Either way the back has to come off the dryer.
Dec 13, 2011 | Dryers
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 | GE Dryers
The iron does not heat up
Hi.
Either wiring is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
Jan 15, 2010 | Steam Fast Irons
Spin cycle does not operate
Dec 15, 2009 | Bosch Washing Machines
Washing machine: water level is high
Nov 22, 2008 | Washing Machines
BOSCH WFF 200L
heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Jun 02, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Open Questions:
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
