Question about Tablets & eReaders
How can I get a pandigital tablet charger - Tablets & eReaders
  • Tablets & eR... Master
  • 3,320 Answers
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: my pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Posted on Aug 05, 2013
Why won't my tablet take a charge?
Assuming you are certain that there is nothing wrong with your Charger I.e. The charger is functioning or if you are using a USB that it can deliver a charge - then the issue is with the battery and it should be replaced.
Jul 31, 2014 | PANDIGITAL Tablets & eReaders
My tablet wont charge.
I tried numerous attempts to fix this problem, including a re-format of the tablet. In the end, I had to trash it. The cord was tested and was fine, the plug was fine, it must be something in the power mechanism of the tablet that failed.
Apr 25, 2014 | PANDIGITAL Digital Book 843967071153...
Unable to recharge my Pandigital SuperNova
If you are using the supplied charger it is bad!
If you are using some other charger, it may not be supplying enough amps to work with your device. Check the specs on the charger, look for one with a higher supplied amperage and try it.
Nov 30, 2013 | Polaroid 4.3" Internet Tablet
Pandigital wont turn on
i have it plugged in will not come on have a green light
showing its hooked to chargr but nothing else works.
Jul 18, 2013 | PANDIGITAL SuperNova
How do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Oct 28, 2012 | PANDIGITAL SuperNova
The place where i enter my charger has broken inside the tablet
That you would need to go either to where you purchased it to be repaired, or they will have to send it out to the manufacturer to be repaired. That is not something you can fix yourself. At least, I would not recommend you trying.
Feb 17, 2012 | PANDIGITAL SuperNova
Pandigital will not start up
1. Is there voltage from charger to plug (Volt Meter Needed) 2. Has unit been dropped or wet 3. How long has unit been down?
Jul 09, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
