Question about Coleman Camping, Backpacking & Hiking
How do I remove the battery?
Hey guys I have a Coleman model 5348-700 rechargeable lantern. I have replaced my tube bulbs and it still doesn't work. I am now sure its the battery, even though when I plug it in the red light works. But when I opened the bottom to get the battery out to go to get a new one the battery won't come out at all. it seams to be glued. How do I remove the battery? Should I take it to a camping store maybe?
  • 398 Answers
This is not intended to be a user replaceable battery, although I have found a replacement battery on-line.so that means that SOME people have replaced them. the cost is $9 +s&h. I don't think most camping outfitters would be able to help you with it, But it would be worth a try.
My suggestion would be (if you have one in your area) take it to a Batteries Plus store. They are quite good at replacing batteries that are NOT meant for user replacement.
Best of luck to you.
Posted on May 12, 2014
  • 1 more comment
  • Ron Dufek
    Ron Dufek May 12, 2014
    Replacement Batteries corresponding toLithonia Battery 5348 700 Coleman...
  • Sara Nelson
    Sara Nelson May 12, 2014
    That is good advise, and makes sense. I have a battery store here where I am so I will head over there. Thank you!
  • Ron Dufek
    Ron Dufek May 17, 2014
    You are welcome :)
4 Suggested Answers
  • 973 Answers
SOURCE: trying to find replacement bulbs for our Swissgear
You can find the bulbs you need at this link; http://www.bulbs.com/eSpec.aspx?ID=14393&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
Posted on Jun 25, 2010
CarlGlas
  • 283 Answers
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Posted on Jul 21, 2010
kelsey146588
  • 4 Answers
SOURCE: Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Posted on Jun 07, 2012
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
try grabbing it with pliers. sounds like it is corroided
Aug 02, 2017 | Coleman Dc 12 Volt Inflate-all Pump
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Nov 22, 2011 | Camping, Backpacking & Hiking
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
Jul 20, 2010 | Coleman Camping, Backpacking & Hiking
Cant figure out how to take apart to replace bulb
More information is required in order to answer your question. However, the following link will take you to the Coleman website for battery powered lanterns. www.coleman.com/coleman/parts/product_category2.asp?category_id=170
Jul 19, 2010 | Coleman Rugged Battery Powered Lantern...
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Camping, Backpacking & Hiking Logo
717 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
weirdtop
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
