Question about Panasonic Televison & Video
Why dose my panasonic pt 52lcx66 tv turns on after 1 min it blinks green and all images disapears ?
Images are normal the first min then images disapear and it continues to flash green and then the tv turns of
    Master:
  • 487 Answers
Major problem with the picture circuit. could need soldering only or components. not a major problem for repair shop but tv probably not worth the repair. time for a flatscreen, same price as repair of this one.
Posted on May 16, 2014
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Off and on
I had this issue it cleared it self it was just after I replaced the lamp. I think the seal around the lamp mount was a little loose I removed it and refitted the lamp it has been ok since.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
After an hour of watching Tv the screen flickers and loses color, green lines come on the screen and the images become blurred/wobble. I can turn tv off for 15 mins and then it comes back fine, for another...
It could be the Digital board. It does most of the video processing before being sent to the Optical Engine. This is a expensive board and I recommend to call a professional to be sure.
Hope this helps,
Skyassoc
Jul 09, 2009 | Samsung DLP HL-P5663W 56" TV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
X box 360
plug in vidio cord to tv!
Nov 02, 2008 | Microsoft Xbox 360 Console
On Daytek LCD DT4040, After some time like 2-3 hour, sometime 10-15 minutes, image from source disapear and red and green line appear... Not actually on DVI input, no trouble since 30 minutes.. on test for...
i have a daytek dt 4040 and when i turn it on,i push the red button ,flash 5 or 6 time and turn green have sound but no image. what the problem
Aug 19, 2008 | Televison & Video
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Televison & Video Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
