Question about Proscan 32" Class LED HDTV with Built in DVD Player PLDV321300 - CURTIS INTERNATIONAL LTD
How can I get tv to go to channel 3 so I can set up satellite picture?
  • 2,509 Answers
Plug everything out apart from the satellite, which you should connect to one of the tv's AV input and select that input on the remote.
Posted on Jun 01, 2014
Can i hook up an old tube type tv to a new high satellite dish? i dont care if i get high def picture just want a regular picture.
Yes there is an option for ouptuting 480i signal from most hd receivers. You will need to check the specifics for the satellite dish receiver as to the channel that the TV should be on as well as how to set it to the resolution that you need. (I know some Dish receivers need channel 60 for the SD TV (coax (RF) connection) when it is TV 2 but channel 3 or 4 for TV 1.) Also check your TV so that you can use the best possible input available.
However, you may not be able to read the closed captions unless you enable them on the receiver. (Apparently, the encoding has changed.)
The manuals for some satellite company receivers are on their website. For example, Dish network manuals are here: http://www.dishnetwork.com/supportsection/manuals . Their manual for the Solo VIP 211k describes connecting the receiver to a SD TV on page 91 (page 97 in the PDF version).
I hope this helps.
(I'm not aware of any satellite system that doesn't use a set-top box. If you do not have a receiver, then the above does not apply and you may not be able to get a signal.)
Apr 13, 2011 | Televison & Video
Sharp TV
Without the specific model number, I can't give you teh exact sequence, but you need to setup the set to only enable channel 3. Work your way through the menus to select channel 3 as your "favorite" channel. Disable all of the others. The set should then turn on as channel 3 at all times. Feel free to post the model number and I'll pass along more details.
Dan
Mar 20, 2008 | Televison & Video
I have a sony projection tv and the picture and sound are there, the cable feed is good, but the picture has a lot of static. Almost like a weak connection.
Check the input channel is 3 or 4 if you are using an external receiver, satellite or cable. If it is set on 4 and the input receiver is 3 then you will have adjacent channel "bleedover". make sure the two units are set on the same channel.
Feb 10, 2010 | Sony Televison & Video
Changing TV set up to cable from "air"
Try setting tv to channel 3 or channel 4, this should coincide with the back of satellite box (a little black switch with a 3 or 4). then switch channels with your satellite box. I would recommend using another output off the satellite box to feed the other tv, a splitter loses some signal quality an can go bad as well. get a long rca cable to feed tv!
Mar 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
RCA D56W20 picture problems
More information is required to properly troubleshoot this problem. How is your television connected when you are watching HD? Do you have HDMI for this, do you have a satellite or digital cable box? For analogue are you using regular coax antenna (cable TV), or are you going through a cable or satellite box?
This could be related to the aspect ration setting. perhaps you ahve changed your aspect ratio from 16:9 to 4:3 or some other setting. If you are connected via HDMI, then the digital signal may be "normalizing" your picture during HD, but reverting back to the other setting.
Check you video settings very carefully. HD televisions are very difficult to tweak properly.
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Apr 29, 2008 | Hitachi 27CX01B 27" TV
Picture lasts only a second
go to menu on tv and put it on air
Oct 16, 2007 | RCA TruFlat 27F520T 27" TV
Proscan 32" Class LED HDTV with Built in DVD Player PLDV321300 - CURTIS INTERNATIONAL LTD Logo
71 people viewed this question
Top Proscan Computers & Internet Experts
David Payne
David Payne
 Mikey
Mikey
Are you a Proscan Computer and Internet Expert? Answer questions, earn points and help others
