Question about Kenwood KDC-C465 6-Disc CD Changer
Kenwood 6 disc cd changer
The magazine is stuck inside the unit of my CD changer. The unit is installed in the trunk. It was playing fine one day until it got to the end of one disc. I then got the E-99 error message. I was able to hit the reset button and everything played fine. Now it just struggles to try to eject the magazine. I do notice that one of the screws mounting the unit is bent but not loose and there was some mild skipping which I had never heard before.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
Posted on May 13, 2014
4 Suggested Answers
  • 20 Answers
SOURCE: Error Message
another problem i have found is that if the changer gets to hot sometime it wont play and by removing the disks it lets it cool just enough to make it work. sometimes by making sure to have enough ventilation in it might help too.
Posted on Jul 07, 2009
SOURCE: Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Posted on Aug 25, 2009
logosc75
  • 625 Answers
SOURCE: No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Posted on Oct 11, 2012
Cartride won't eject
The magazine may not be able to eject because a CD is stuck and not completely seated inside.
Mar 26, 2014 | JVC Xc-m75 Kenwood 6 Compact Disc Magazine...
Panasonic 6 disc changer has suddenly stopped playing CD's and now shows E-1, E-2 and so on, messages while trying each disc sequentially, in my Opel Astra. I have tried the reset button to no ava
A CD may have gotten stuck moving from its slot to the play mechanism or while returning to its slot. If repeatedly pushing the reset button does not restore operation or make it possible to pop out the magazine, you may be in for a difficult task of removing the magazine manually but the stuck disc has to get unstuck first
Sep 25, 2012 | Car Audio & Video
Error 01 the magazine does not eject
A lot of times there is a gear inside of the changer that gets jammed. If you can, remove the top cover of the changer. On the changer mechanism (it will be on the right side of the changer) there will be a large gear (probably black) with an arm attached to it. Use a flat blade screw driver or something like that and turn the gear counterclockwise until the tray is back in magazine. You should then be able to put the changer back together and it will probably work fine.
Nov 02, 2011 | Alpine CHM-S620 6-Disc CD Changer
How do I remove a stuck 6CD changer magazine?
Our Bose has a 5 CD player, So, I'm not sure if this is the same for your base unit, but here goes. You'll need: a bright light and a small screwdriver that reaches inside the chassis (or equivalent).
1. Disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Using a bright light, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. When you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in teh player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Feb 19, 2011 | Bose Lifestyle 20 System
The magazine for my CD 12 disc changer will not eject nor will it play ant CDs. It seems to be getting power as the light inside the slide door lights up as open to eject the magazine any suggestions? It...
theres usually a reset button hidden inside the door on the cd changer. use a paperclip to reset the device. sometimes theres a reset on the controller part of the cd changer Up by the radio ( if you have tha type )
Jul 31, 2010 | Pioneer Car Audio & Video
I have a kenwood kdc-c469 6 disc cd changer
try pacparts.com. they should be able to get you a price on a magazine.
Feb 16, 2010 | Kenwood KDC-C469 6-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
1999 Ford SE digital display reads ''NO CD'' and changer is stuck
Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
Apr 15, 2017 | 1999 Ford Taurus
6 CD Changer Jammed (Audi A4)
You may have to remove the unit and disassemble it to remove the CD that evidently is jammed inside. If your unit has a removable magazine that holds the CDs, the magazine probably is stuck.
Oct 22, 2017 | Car Audio & Video
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Kenwood KDC-C465 6-Disc CD Changer Logo
281 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
