Question about Cub Cadet Garden
Why my 2006 cub cadet model 1529 will not go up a hill forward or backward ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Change oil andf filter it should work then
Posted on Dec 17, 2014
  • 246 Answers
SOURCE: i have a cub cadet model 3 1042 it starts but
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 109 Answers
SOURCE: I have a cub cadet Zero turn mower Z50 and when I
On the transmissions, there are bypass levers...make sure they are pushed in and not pulled out
Posted on Jun 13, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
oldmanewtoys
  • 414 Answers
SOURCE: My daughter gave me her old Cub Cadet model 2145
linkage is connected correct? Did it work prior correct? Did you prurge after changing fluid
Posted on Mar 05, 2010
Testimonial: "Well you were exactly right. I had to remove the two plugs on top and kept operating the lever until I got the oil to run out the top. Runs great."
SOURCE: cub cadet starts but won't move forward or reverse
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Posted on Apr 22, 2010
Cub cadet sltx1050 wont go forward or backwards? was w orking fine then we had to push it backwards to jump iot cause it wouldn't start and now it wont move forward or backward
There are two possible options one is the belt for the drive is shot, the other is that the transmission is shot we tend to go out.
Nov 08, 2017 | Cub Cadet Garden
I have a 0 turn cub cadet lawn mower and when we go forward or backward it makes a whining noise is it normal.
I certainly would check the fluid level for the transmission . tho they will make some noise.
Feb 10, 2016 | Cub Cadet Garden
Cub cadet model #1529
bad pto clutch shorting out shutting down
Jul 06, 2014 | Garden
Cub cadet model 13WQ91AP056 won't move backwards or forward
get a jack to lift backin of mower and you will have to remove the deck to get to linkages i dont think thats the problem change hydr fluid and filter and see ifthat take care of problem
Jul 05, 2014 | Cub Cadet Garden
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
Cab cadet 46
run power cable from positive of battery to pto it should click and move
Aug 29, 2012 | Cub Cadet Garden
Cub cadet SC621
The front castor wheels may need lubricating, do they swivel freely?
Aug 16, 2012 | Cub Cadet Garden
Garden Logo
117 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
