SOURCE: the washing machine samsung is licking from de
Replace the round rubber sealing washer located inside the hose. There is on on both ends of the hose. Tighten snugly. All hardware stores carry these replacement washers.
SOURCE: washing machine is connected with
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
SOURCE: my samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
