Question about Philips 43PP9202 43" Rear Projection Television
Yello colour and fuzzy
We have been very happy with this tv but cannot get the colour right. Can no longer find manual to correct. Please help.
  • Philips Master
  • 8,617 Answers
The coolant will most likely need replacement. Heres alink to the repair kit which contains the coolant and detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Posted on Jun 24, 2009
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
Why are my channels fuzzy?
Hi Virginia,
I have the manual link for you for your TV, basically your issue falls into INPUT issue. Kindly check if the INPUT of your TV is correct. Steps below:
- INPUT SELECT button- Press to select
TV or the external input (VIDEO1,
VIDEO2) mode.
(See USING AUDIO/VIDEO INPUT JACKS.
- AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
a video camera or VCR.
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
These steps is in page 2 of the manual. Hope it helps.
Emerson EWF2004 Owner Manual Page 2 Table Of Contents
May 05, 2014 | Emerson EWF2004 20" TV
My vpl-es3 picture is not clear....showing fuzzy
is the lens focused properly.
is the DOT Phase on the input setting correct.
is there condensation on the lens.
what sort of fuzzy do you see. is it all over the whole screen. is it coloured or only one colour.
is the screen resolution matched to the video source
Mar 13, 2011 | Sony VPL-ES3 Multimedia Projector
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
Tevion tv won't display normal colours on PAL 60 setting
Look behind of the TV for trim adjust potentiometers. If there are any of them, you shall open your tv's backcase, look for Crominance trim and adjust it manually. If you have no electronics knowledge, i wouldn't not recommend do it "for pratice", you may distroy the TV, end in the hospital, or into a coffin.
Nov 20, 2009 | Televison & Video
I have sound but no pitcher from video
red, white plugs are for left and right audio..... yellow is video, your tv may not have a video plug, just speaker plugs
Jan 21, 2009 | Philips VR550 VHS VCR
Re: Nintendo Wii console setup Just setting up my Wii for the first time. The power leads are in correctly, audio and sound cables are also connected. However, when I go to the AV channel, there is no...
Hi! Happy to try to help. Make sure you have completed all the steps in the order they appear as on the quick set up sheet included with your system. Check to see if you have the wii both plugged into the tv as well as the power outlet. You should be able to get hooked up using the 3 color a/v cord, this is what works for us. Do you still have the manual? Be sure to check page 18 of the white Wii operations manual to be sure you are using the correct input setup. Please give me a great rating if I have been of help. Otherwise, please let me know how else I can help. Thanks!
Sep 03, 2008 | Nintendo Video Game Consoles & Games
Philips rear pro 46PP8621 ..fuzzy image, lower screen has a wavy section with distorted image, very noticeable with text.. this section is a bright green colour. Colours seem to be ok......... with...
Your tv is probably in need to replace the color disk. Follow instructions on last pages of your manual to find out hou to get repair service.
Jul 24, 2008 | Televison & Video
Dark picture and shadows
Sounds like you've entered the "service mode" where you're seeing the chroma (color) signal only. What type of connectors are the F and S? RCA? F? This set is no longer made which makes it hard to research. By any chance, is there a small switch on the back that says "normal - service"?
Nov 06, 2006 | GE 25GT516 TV
Philips 43PP9202 43" Rear Projection Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
