Question about Passport 8500 X50 Radar Detector
Laser alarm gos off when accelerating - Passport 8500 X50 Radar Detector
  • 4 Answers
It probably just needs to be cleaned. I use canned air and Qtips to clean the areas around the PCB's and sensors and that fixes this issue. It is simple to take apart and only fits back together the right way.
Posted on May 23, 2014
This is a common problem with the older units, the Laser horn gets dirty and out of alignment causing this issue. You can send the unit in for repair or try to fix it yourselfe
Posted on May 20, 2014
How do i disable my 99 acura tl alarm?
hi
once you unlock the car with the remote of key
leave the door open
look under the dash until you find the alarm box remove the fuse(s) that plug into it
this will disable the power to it
25718656-extj4arg1t42xbh3l3byl5v2-3-0.jpg remove the blue one that the red wire gos into as this is the power one.
cheers
May 29, 2015 | 1999 Acura TL
Have viper alarm but wont let me start my engine how dp i disconnect the alarm
hi
open the door \
check under the dash form the car alarm box
25609464-extj4arg1t42xbh3l3byl5v2-3-1.jpg remove the power fuse
25609464-extj4arg1t42xbh3l3byl5v2-3-3.jpg the fuse that the red wire gos into thats the power
cheers
Mar 26, 2015 | Viper Vehicle Parts & Accessories
CAR ACCELERATES AT FULL THROTTLE ON KICKDOWN
CHECK THE SPRING ON THE ACCELERATER RETRUN IT MAY BE OFF OR BROK
Jul 17, 2014 | 2008 Audi A8
Only use these remotes to lock my car. Alarm keeps going off when no one is around. Any idea why?
hi
alarms normally activate when they are trigged
do you have a bonnet door or boot switches connected to the alarm system
you have to eliminate each switch
open one door at a time and hold down the switch
lock the car with the remote if it gos off its not that door
move on to the next door and repeat the process
if it does the same thing with all the doors there working properly
go to the boot or trunk and hold down the switch if it gos off thats good
go to the bonnet or hood and hold down the switch if it gos off you thats good have eliminated all switches
if at any time any one of them dosent go off you have found the problem
try that first
aries
Oct 12, 2013 | 5101 LE 1 Way Car Remote Starter System
My alarm gos off and drains my battiery how do i turn the alarm off
I am not a mechanic nor a expert but my suggestion is to disconnect the alar or if uses a fuse, take it out. I would see if it has a fuse being it might be easier the diconecting.
Jul 01, 2011 | 1992 Lincoln Town Car
Battery died got jumped off now alarm goes off for no reason
there is a reson why the alarm keeps going off, you havent reset it yet
if the battery gos flat the alarm "forgets" were it was set at,,easy fix realy
Jul 04, 2010 | 2008 Mazda Cx 9
2003 mitsubishi eclipse wiring diagram
I own a 2003 mitsubishi spyder eclipse GT and my alarm fob broke off its key chain so I havent been using it lately (waiting for replacement). Today I went to use my car (unlocked and opened the door with the key) and the alarm activated. The car still starts but I have to wait till the alarm gos through its cycle before I drive anywhere (embarassment of course). How do I disengauge the alarm system till I get the new fob?
Feb 01, 2009 | 2003 Mitsubishi Eclipse Spyder
Sometimes will not start
whenever you loose RPM it indicates that the ECM is failing and usually after the vehicle cools down it will start like nothing happened so the first place to start with this problem is the vehicles ECM
Oct 25, 2008 | 1996 Jeep Grand Cherokee
Passport 8500 X50 Radar Detector Logo
60 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
